My back-up lights don't work...My fuses are all ok and my bulbs are fine...there is no current at the bulb sockets...
any ideas??  ...I haven't messed with any of the light wiring other than splicing into the 3rd brake light for my pro stock wing...
_
2002 LS Sport coupe
You messed up the tailight wiring.
Check for voltage at the fuse block...that will tell you if you screwed up a wire or if its something before the fuse...switch maybe.
5 spd...
I never touched the taillight wiring...
I'll check the fuse block voltage...
_
2002 LS Sport coupe
I believe on my camaro transmission there was a sensor on it.
Check it out..sorry..im trying..
2 cents aint much unless your broke.
i mean my camaro had a sensor on the tranny..check your out..maybe you have a sensor on it that is faulty.
good point Gary...anybody know where the sensor is?
_
2002 LS Sport coupe
its on the driver side of the transmission
mine went out about 3 months ago, but it was still under warranty so i took it to the *shudder* dealer and they put in a new switch, but the idiots decided to be lazy and mount the new switch to the inside of my bumper instead of where it should go
but yea chances are its the switch gone bad
Its the back up lamp switch.  No biggie.
Semper Fi SAINT.  May you rest in peace.
thanks everyone...the switch makes sense to me, I'll go that route...
_
2002 LS Sport coupe
i just did mine a few weeks ago....
take off the front drivers tire and you will see the switch right there.  Took about 10 mins to change it out.
