alright i'm going with hp racing 4-2-1 header to the magnaflow high flow cat to a 24 inch resonator to a borla cat back...will the clamps be ok or should i just get them welded?
weld. With clamps you have a bigger chance of leaks which is not cool for performance
yeah that's what i was thinking...especially when you're starting with a 2200, any leaks would kill it...although there isn't much to kill
welding is best , also detures theft (makes it harder to steal anyways)
but the clamps should work ok
i have seen a post on the jacked wrecked forum that someone stole someones muffler..... so it does happen..
Guy where I live had one welded on his car, but never paid the guy to do it, so the guy showed up one night and cut the muffler off and took it back
My buddy now owns the muffler.
Weld it. Mine leaked like crazy before I welded it. The leaks make it sound awful. There's actual still a leak somewhere even after welding it. ??? Not sure where. But, yes, definitely weld it.
welding never hurts.....
experience the "tilt"....... Yeah the whole right side of your car when im passing your a$$.......
I would like to weld mine but the stainless is pretty hard stuff to do. Guess I will have to take it to someone good.
if you have a welder than your good to go, but if you don't and you need someone else to weld it up for you like a shop ...etc. then i'd put at least 2 flanges in there just incase you need to take it down or a part of it down inorder to do install/repair something..if you fit flanges with gaskets correctly, i highly doubt there will be a leak, and your prepared for any faults to happen in the future
