Ok I have been trying to do some research on this..
from what i have found it says to get the 2.3 HO manifold
the tb is a direct swap from the old tb...
can the people who are knowledgable on this topic fill me in as to what else is needed for the swap.
Also how do I know it's an HO and not an LO
Thanx guys.
I'll keep searching and answer my own questions if I find the answers.
the engine where you would pull these items off of. the engine will say 2.3 HO on it.
sounds good... are there any other pieces I need to hook up the tb and the manifold?
ok that explains alot....which TB is better to use?
if I were to use the 2.4TB does it need to be modified?
nevermind I just found out what I would have ot modify on the 2.4TB
but again..which TB is better to use?...like pros and cons of both?
and are there any mods that you can't do after installing the manifold?
