was jw how similar (if any at all?) the upper mounts are between a 2.4TC and an ecotec 2.2...
id like to buy an ecotec rk sport upper mount and use it on my 2.4
so......is it posible?
thanks
Black 97' Z24
Blacked Out and Lovin' It...
"Z Yaaaa"
im not sure which way the mounts are , but 1 sits up higher than the other 1 does , the bolt spacing is right on
the 2 are totally different
Ecotec mount
2.4 mount
the Eco is a total replacement i think
the 2.4 upper mount is an insert.
yeah i know- i have the 2.4 insert-was just looking for a neater looking peice, as well as a total replacement
Black 97' Z24
"Z Yaaaa"
The Z mount sits higher than the eco. I did the Z mount in my car like a few other people before the RK one came out. The passenger side of my engine was probably about half a inch or so higher than stock and the intake rubbed my hood. That sure was a waste of $125 lol
As for your question yes you can use a ecotec mount on a 2.4 motor.
uhm ok, could u explain some details for me? please? john?
Black 97' Z24
"Z Yaaaa"
Yes the monut will work, bolts right up. Its just that your engine will be sitting at a angle. The passenger side will be lower than the rest
ok then, i have a guy that can make pretty much anything out of billet aluminum...
would there be a way to maybe put some sort of a spacer somewhere?
or would it haveto be steel? either way, would that be posible?
thanks
Black 97' Z24
"Z Yaaaa"
Fast97z24 wrote:ok then, i have a guy that can make pretty much anything out of billet aluminum...
thanks
Yeah you could definately have spacer made. Just not sure if the bolts on the frame are long enough.
