After how much moding would i need to upgrade my fuel,and ecu,ECT????
if you go forced induction, after about 6 psi. but yes the stock system will support every bolt on plus some internal work, but not too much more. upgrading also kinda depends on what motor you have. which... fill out your profile if you would.
Spotabee Racing wrote:if you go forced induction, after about 6 psi.
if you go forced induction, you'll need some kind of fuel mods for 1 psi. stock system will not support boost.
_________________________________________
450WHP Turbo Ecotec swap in the works...
Spilner521 wrote:Spotabee Racing wrote:if you go forced induction, after about 6 psi.
of course, but i was referring to injectors and pump.  i should have clarified.
