Ok, I want some of your opinions on what to do next. Im not looking for boost or n2o. I have a intake, pacesetter header, hi-flow cat, and 2.25 piping. I just ordered my crank pully.
well, where do you wanna go with your car? you can do suspension, more performance mods, etc etc
Right now Im looking for more proformance. Suspension is almost done. Forgot, I also have motor mounts.
What would new valves with a 3 angle valve job do.
Get a spare TB and send it to port and poolish it to like 56 mm- 60mm
a valve job is good. but you wanna go and open up the entire head. valve job, P&P, probaly a set of cams.
Its a custom valve job that will allow more air to your cilinders.......
Yeah, if you wanna get a nice performance upgrade, you should get a port and poolish job, a custom angle valve job and research for some good cams for N/A cars since you dont wanna go for booost.......
If you do that, you should get about 15-30 hp and with the ported TB, extra 5-8hp
possibly a flywheel or clutch?....both
i know you don't want to go nitrous or boost yet but do you plan on going that route eventually? If so just saave the cash and peice together your own turbo kit or bank it and buy from hahn. I don't regret going nitrous execpt for the fact that I'm now addicted and the guys at street stuff see me at least once a week.
If you do plan on going either route eventuallly build the head with those mods in mind. You could buy cams that were ground for boost or the juice..... thats about all i can think of.....or you could go the msd route.
I would say:
Cams (stage 2)
Headwork (P&P, 3 angle valve job, etc...)
Ported Throttle body and possibly intake manifold
Thats what I can think of right now. Witht hose there, you could run a little N20 and really feel a big difference. I would set aside a decent amount of cash for what is posted. Cams aren't too bad (should be under 400) headwork can be expensive (1000) and the TB (under 100) and ported manifold (possibly diy). Good luck.
I'll have a sig someday....................
Nissan for sale drop me a line!
