engine swap - Performance Forum
engine swap
Tuesday, November 15, 2005 3:22 PM
i want to do an engine swap in a 97 Chevy cavalier 2.2L i know i should use the search but i can't b/c i don't have a home computer anymore b/c of hurricane Katrina i have a manual tranny and i was wonder if i could use 2200 motor with it. and all so if i get 2.4L with the tranny what all would i need? any help is cool. thanks
Re: engine swap
Tuesday, November 15, 2005 5:08 PM
Hey does any one know if i can swap a 2.2 ecotec into a 97 z24,and what kind of performance gains or losses will i get.I have a 2.4 now,want to go to ecotec and five speed trans...can some one help
Re: engine swap
Tuesday, November 15, 2005 5:37 PM
xio wrote:i want to do an engine swap in a 97 Chevy cavalier 2.2L i know i should use the search but i can't b/c i don't have a home computer anymore b/c of hurricane Katrina i have a manual tranny and i was wonder if i could use 2200 motor with it. and all so if i get 2.4L with the tranny what all would i need? any help is cool. thanks
I believe the bell housing is different between the 2.2 OHV and the 2200s but quote me on that.
If you were to pick up an 2.4 w/transmission, you would need the PCM, fuel system, ignition system and basically all the hoses and wires that would be found in the engine bay.
Pretty much the same answer...
There really isn't a big difference in the 2.4 and ECOTEC...honeslty I would keep the 2.4 unless you have high mileage and want to swap in another motor, than yes, an ECOTEC would be a good choice.
Re: engine swap
Tuesday, November 15, 2005 7:26 PM
get a HO..gain almost 30 hp and itll bolt to your existing tranny...
"Freedom 'ought to have its limits"-George W. Bush may 31 1999 (who voted for this idiot?)
Re: engine swap
Tuesday, November 15, 2005 10:30 PM
HO power! and don't mean that in any other way than High Output... the motor you pervs.
Re: engine swap
Thursday, November 17, 2005 1:35 PM
so the ecotec will go right in w/a harness change and will my trans bolt up?
Re: engine swap
Thursday, November 17, 2005 1:42 PM
dj pike wrote:so the ecotec will go right in w/a harness change and will my trans bolt up?
no, an eco will not go right in. different mounts. and no your trans will not bolt up
Re: engine swap
Thursday, November 17, 2005 4:00 PM
where he get that from?
Re: engine swap
Tuesday, November 22, 2005 4:01 PM
hey thanx for all the help guys......
Re: engine swap
Tuesday, November 22, 2005 4:10 PM
welcome
