I have 2 grand to spend on my car. I want to turbo my car, i allready have the turbocharger, oil feed, return lines, and flanges. All i need really is a BOV, mani, front mount cooler and wastegate. Or should i go a diffrent rout. I wanna do something performance. I allready have full exhaust...header to exhaust. i have pulleys, motor mounts, ground wire system, and some other little @!#$ like that... What do you think.
make it handle!
suspension. It goes fast, now make it corner fast.
-Chris
i have a sub frame brace, strut tower brace and tires. i dont know if i want to lower it tho cus its is low with the kit...
supercharger. pulley and alchol injection
"IF YOU PERSIST IN DOING WHAT YOU HAVE ALWAYS DONE .....
EXPECT RESULTS NO DIFFERENT FROM WHAT YOU HAVE ALREADY ACHIEVED"
Finish collecting all the turbo supplies you need, 2 grand and you already have some of the stuff..finish it up! Once the turbo setup is done, get it installed (whether its you or a shop). You won't get through 2 grand with just that so spend the rest on building her up so you can crank up the boost!
Wow I wish I had that much to invest..good luck!
Blown.
If you have another $2000 to spend, spend half on suspension (for $1000 you can have an awesome handling cav) and then spend the rest on finishing your boost project.
Spotabee Racing (The Fake Z24) wrote:If you have another $2000 to spend, spend half on suspension (for $1000 you can have an awesome handling cav) and then spend the rest on finishing your boost project.
i agree pro kits/agx's with a rear bar and slap on control arm bushings and brake lines and pads. then he would have a solid base.
see ya!
I say finish your turbo kit...it gets very difficult to try and do 2 projects at one time. My belief with modifying is to finish one thing and then go to the next thing. It's better to have 1 finished project than 2 incomplete in my opinion.
Get a LSD and finish off your turbo project.
Totally tubular, dude!
"Sig under construction"
i think im gonna go turbo route. How much would a shop charge to install...and do they tune it....also...show i replace all vacume lines???
It depends on the kind of shop it is. If it's a performance shop that regularly does FI systems and turbo installs then I'd guess around 7-800; I, personally, wouldn't pay more than that. I suggest just doing it yourself if you have the time. Its a great learning experience and you'll understand boost alot more.
For tuning it all depends on what you have to tune with (i.e. wideband, standalone, etc.). A performance shop would be able to do it but I'd see what you can do before you give them your money. Do what you can and then bring it to the shop and have them dyno tune it.
I didn't replace my vacuum lines when I boosted, I don't see why one should. Maybe someone else can answer this better than I can.
Blown.
Don't pay a shop to install a turbo kit on your car. Do it yourself.
ok, cool...anyone around the chicago area want to help me with this project when i get all the parts. ill slip you some money...or possibly a header. I want to have this finished before the 26 or january for world of wheels.
Jason Ruggiero wrote:ok, cool...anyone around the chicago area want to help me with this project when i get all the parts. ill slip you some money...or possibly a header. I want to have this finished before the 26 or january for world of wheels.
I'd help out if I was closer and if I wasn't already practically booked over break with stuff going on here in KC
Try a post in the regional forum for anyone willing to help, unless that's considered cross-posting (don't see how, though; it's a different subject for a post).
Blown.
ok, thanks everyone for your input....and this thread can now be closed.
I will keep everyone posted on the install as soon as it starts.
