Step by step guide to installing the AEM Cold air intake on a 98+ 2200 ln2.
Items included with intake should be...
Step 1: Disconnect your cars battery and remove from engine bay.
Step 2: Remove you factory airbox, expansion box (says 2200 on it), bong in dirver side fender, air tube with IAT sensor, and strut tower brace equipped.
Step 3: Remove tab from underhood fuse box and place fuse box out of your way (tab is no longer needed).
Step 4: Install supplied bolt and washer in the inside wall of fender.
Step 5: Install METAL spacer and place shorter intake tube into the hole left by the stock air box, Secure with nut and washer.
Step 6: Place supplied rubber hump hose onto your throttle body and secure with supplied clamp.
Step 7: Install rubber grommet into hole on the side of the larger intake tube. Install the unpluged IAT sensor into the grommet.
Step 8: Install final rubber boot onto the end of the smaller intake tube and secure with supplied clamp.
Step 9: Install the larger intake tube into the rubber boot on the end of the smaller tube and the hump hose on the throttle body.
Step 10: Place rubber spacer in tab hole that holds the fuse box on, secure with supplied nuts and washers.
Step 11: install the supplied breather hose from the rocker cover to the inlet on the side of the intake.
Step 12: Use supplied zip-ties to route throttle cable and cruise control cable (if cruise is avaliable) to top of the intake.
Step 13: Install the supplied AEM air filter to the end of the smaller tube located in the inner fender.
Step 14: Reinstall battery and IAT sensor connector.
Final product....
Oh and look a the detail
Warning!!! I am not responsible for any damages to you or your vehicle durring the install of your AEM CAI, Please use caution when working with any tools or electrical items in your car!
What is an intake?
Nice step by step
What is it that the newbs ask..."what is the loudest intake?"
nice
looks like you got the newest filter too , the synthetic filter that requires no oiling , and is cleanable
nice pics even though the lighting kinda sucks for some ,
[quote=97cavie24ls(JDM&00s/c sedans™)]nice
yea it was 30 outside so i did it in the garage
thanks for the comments fellas, And i did notice a minor gain over previouse intakes.
only 30 , you wussy
are we gonna have to revoke your rights to drive a silver cav
LOL ,
yeah 1 of the guys here got the aem also , and had a mickey mouse made 1 before that was quite , and said he notised a nice difference in performance and sound with the aem
Looks good, need more light though hehe
2012 numbers - 4SPD
AUTOMATIC!!
I liked this intake when it was on my car. I didn't have the new filter on it obviously though because I got the intake about 2 years ago.
Great write up.
sweet i just got that intake to replace my vibrant intake..hope it helps..phil
looks like the filter is sittin right behind your light in the one pic...or did u just slide it in the hole and it sits in fender? awesome write up by the way.....maybe this should be a sticky!
Creative Draft
Creative Draft Member
the filter sits just behind and below the corner light.
so do you need to take off wheel like ppl say? or can you do it w/o takin it off? just curious cuz i am thinkin bout gettin this intake.....also...you get the CEL like everyone else apparently
Creative Draft
I dont have a CEL from the intake, I do from a crappy Catco converter though.
I did not remove the rim, or the inner fender. I only removed the corner light, But the directions do say to do so that come from AEM, they even say to remove the washer bottle during the install but I didnt do that either.
ok..thanks for the input...one more thing...who did you get it thru?
Creative Draft
[URL=www.turbotechracing.com]Turbo Tech Racing[/URL]
Phlatcav wrote:[URL=www.turbotechracing.com]Turbo Tech Racing[/URL]
Phlatcav wrote:Internet Own3s me
thats it turn in the silver sedan , you shall now only beallowed to own a j in rasberry (the oddball pink as it is known)
http://www.turbotechracing.com/productcart/pc/intro.asp
When did AEM get you guys that kick arse intake?
Is there one that goes to the fender for the 2.4L like you guys'?
Probably not...boooo
But I am diggin those new filters...a little.
-M
they are about 2 years old now
RoNuS20 , was 1 of the test cars for it
I remember them being out.
Never realized about the fenderwell area though.
Oh well, back to the original plan.
Tanks folks,
-M
