has anyone seen this yet?? I really don't want to go through the 2.3L swap. My luck something will go wrong and I will lose the motor lol. Its not too expensive, I thought about doing this and using a Melling Oil Pump. Im going to have them do the Lightening/Knife-Edge Service on my crank and was going to try this too. any coments?? heres a link.
JBP LD9 Neutral Balance Shafts
View my MySpace
yep, im glad they have this too.....they have been doing more things for the 2.4l then ever....im happy too, since i will be sending alot of stuff thier way in a couple months...
2000 Camaro V6.
| SLP Loudmouth | CAI Intake | HID's |
just get an Eco and then you can just cut them off and keep the gears as idlers
hahaha
id say go for it be worth it id say
The one, the only, ME.
Hum, nice find
This is what I plan on doing as well. This along with their High flow oil pump.
well does anyone know anything about JBP's oil pump?? anyone useing it?
View my MySpace
firebug wrote:well does anyone know anything about JBP's oil pump?? anyone useing it?
Thats in my plans as well lol. Im not sure if anybody has tried it. I don't mind, Ill will. Im sure JBP is good for a good product.
2012 numbers - 4SPD
AUTOMATIC!!
is there any other options for the 2.4 oiling system?? I just want to make sure everything is nicely oiled when I go for the 300 mark.
View my MySpace
The reason for doing the 2.3 swap is to improve the oil pump, removing the balance shafts is just a bonus in the process.
The 2.4 sucks at high rpm.
The 2.4 pump is a Melling pump from the factory.
Melling does not make a High Volume (flow) 2.4 pump. Nor does anyone else no matter what they claim.
JBP may sell High Pressure version of the pump. This is the same pump with a washer or 2 placed over the relief spring to increase its tension. This increases output pressure, but not high RPM volume. Lack of volume is the problem that needs to be corrected.
sig not found
protomec wrote:JBP may sell High Pressure version of the pump. This is the same pump with a washer or 2 placed over the relief spring to increase its tension. This increases output pressure, but not high RPM volume. Lack of volume is the problem that needs to be corrected.
Damn, thanks for that info. I had no Idea.
2012 numbers - 4SPD
AUTOMATIC!!
Where can I get a windage tray from a 2.3 does anyone sell them new or do you have to get one from the recycler yards?
2000 Z24 5spd header & catback for now.
^^ There's a part# floating around here somewhere.
22536409 Baffle
I think.
sig not found
windage tray is.......22536409
2012 numbers - 4SPD
AUTOMATIC!!
That part number ^^ doesn't show up on gmpartsdirect probably because its diconntinued, but thats the part you need if you can find it.
The screen part# is 22539133
word to the 2.3 pump swap...... it should be your FIRST purchase when building the bottom end.
SPD RCR Z -
'02 Z24 420whp
SLO GOAT -
'04 GTO 305whp
W41 BOI -
'78 Buick Opel Isuzu W41 Swap
^^See, I would love to but what in the world would I tell the machinist, that I want the 2.3 oil pump conversion? Wouldnt I have to tell him step by step instructions on how to do this? Or would he just look up the specs on a 2.3 motor and do that to my 2.4?
I dont even know if all of those part#'s are correct on page 2 in the faq's lol
hey brian I remember you had a post awhile back that was asking for pics and info on the 2.3 swap to show your machine shop how to drill the holes. still got those pics?? can you email them to me?? Thanks
fire_bug_24@hotmail.com
View my MySpace
You've got mail firebug
firebug wrote:hey brian I remember you had a post awhile back that was asking for pics and info on the 2.3 swap to show your machine shop how to drill the holes. still got those pics?? can you email them to me??
Can you hook me up with the pics and how-to? I can host them on my web space too if thats cool.
ok, since im a complete idion on the 2.4 are jbp just removing the balance shafts in essence? and if the are cant you just cut them out?
For the DSM all i had to do was take them out, turn the bearings to block the oil, intall a stub whaft on the oil pump and plug off the other hole for one with a cap. Is that like the ecos?
Is the 2.4 designed to where you still need them to run and cant just remove them?
Please give me some info, im curious on this now.
ok I just read the 2.3 pump swap on page two in the faq. Im pretty confident that I will beable to pull it off. anyone have any thing else to add to the "how to" in the faq? Is it pretty accurate?? about how much did this people money wise with parts?? Im buying a spare block soon to do first. Im off to do some more searching. Thanks.
View my MySpace
