I'm looking at the RKsport fuel pressure riser kit. It's like $260 bucks and all it looks like is a fuel pressure regulator. Anyone have on of these kits, and is it worth the $$$?
There is no need to get an FPR and raise your fuel pressure if you're not boosted. It's really a waste of money because your fuel system is more than sufficient enough to handle the bolt ons you have and even little motor work that you might do in the future.
Ok but why does Rksport claim a 6 hp increase using the kit???
Chris Oleson wrote:Ok but why does Rksport claim a 6 hp increase using the kit???
Marketing. Just like IAT resistor mods will net you 20+hp, and the Venom 400 actually works.
If you look they say "can" increase by 6 HP. They aren't going to gaurantee you power and like James said, it's Marketing. You see 6 HP, 10 HP, 15 HP and your wallett starts to itch you in your pocket to take out your money and spend it. In the reality of performance, there is no gaurantee amount of power, there is no right way to modify something and there is no set # of HP gains per modification. There are modifications out there that can DECREASE your performance like this one for example. Say you install this and increase the fuel pressure, you're going to run rich because it's fuel that you don't need that's being thrown into your motor.
Before you do any fuel modifications, you need to check your A/F ratio or take your car to a dyno shop to see if you are running learn (which I highly doubt) or rich.
Alot of places want you to always think that bigger is always better and the little bolt ons make a HUGE increase in airflow or change in airflow that you need to upgrade every little part of your fuel system, which isn't true. It's good that you did ask before you bought it though, so take my advice...don't buy it.
Thanks man I see your point...
Chris Oleson wrote:Thanks man I see your point...
No problem. That's why I'm here.
font=arial]A guy posted on this exact product 1-2 months ago, and I told him not to get it. Turns out he already had it
Poor guy, hope he was able to get rid of it on eBay or something.
I find it hard to believe RKSport would put something out like this?? Or maybe not, I can't find it anywhere on their website but Gravana is selling it. I read the instructions, is it replacing a stock regulator? I dont get how it can raise the fuel pressure its mechanical and does it just have a flat setting or does it somehow know when to change fuel pressure by RPM range?
15.71 @ 87.9mph 9-17-05
