stevefire wrote:I wouldn't go with standard sized bearings unless you know your crank does not need a regrind. Get the regrind and get the shop to order the correct sized bearings.That's not a bad price at all (in US $'s). A hell of a lot less than I imagined.
I paid less then $600CDN for a crank grind/balance, balanced rotating assembly, align hone, overbore, cam bearing change, pin fit, ring gap, 3 angle, head decking, and prep wash.
Dale Young wrote:LD9 Fury that's not necessarrily true because JBP may have had to turn the crank undersize in order to get clean round journals, so call them and ask them if the crank was turned or not. By the way I'm gathering the exact same parts as you for my turbo buildup and I'm going to just pay JBP's 86$ core charge along with the $250 charge for knife edging and lightening and not have to worry about sending them a crank. That's what the core charge is for once you pay that you're done, and if you send them a crank first then you don't pay the $86 core charge just pay for the knife edge and lightening.Just wanted to point out to you that JBP has new rules about core charges on their homepage.
Also TurboTechRacing.com has the LD9 Eagle rods on sale right now for $289.99, I just ordered mine, and in two weeks when I get paid I'm gonna order my crank.
What head are you going to use, make sure to use ARP head & main studs.
SpeedRacerZ wrote:one....... if going for High HP.... dont grind the crank down..... makes it weaker (just what I have been told over the years of working on these engines.... both the quad 4 and twin cam)I'm don't think I'm going for crazy-high HP, just looking for maybe 230-250 @ crank turbocharged if I can pull it off. But you never know, everyone says boost is addicting so there's no telling where my HP will be once all is said and done
two..... if you dont have spun bearings, more then likely you wont need oversized bearings. The bearings are made of softer meterial then the crank and block, so all the wearing done should be in them, not the crank and block. But its always best to check bearing clearences when installing them (which is REALY easy to do).
three..... most machine shops dont work on cars, they only work on engines/transmissions. More then likely you will have to pull your own engine and bring it to them.
four...... order standered bearings, right before you need them..... that way if it turns out you need oversized (which I doubt) you can still return them..... NAPA carries the Clevite bearings.
and five..... if not going for huge power, go with the N/A Cometic Gasket..... should put you at about 9.2:! compression I believe (cant say for sure, cause dont have the measurments of your pistons) which is fine for boost. I have 9.4:1 in my current setup (9.5:1 pistons, .074" head gasket, head shaved .010")........
hope some of that helps.
oh yea..... my Cometic head gasket is EXACTLY the same diameter as my cylinders, and I bored mine .040" over.....
Dale Young wrote:Also TurboTechRacing.com has the LD9 Eagle rods on sale right now for $289.99, I just ordered mine, and in two weeks when I get paid I'm gonna order my crank.
LD9 Fury wrote:I'm don't think I'm going for crazy-high HP, just looking for maybe 230-250 @ crank turbocharged if I can pull it off. But you never know, everyone says boost is addicting so there's no telling where my HP will be once all is said and done
NJHK (The Turbo Negro) wrote:LD9 Fury wrote:I'm don't think I'm going for crazy-high HP, just looking for maybe 230-250 @ crank turbocharged if I can pull it off. But you never know, everyone says boost is addicting so there's no telling where my HP will be once all is said and done
HAHAHA yeah right!
Trust me, when you have a fully rebuilt motor that can handle probably more than you'd be able to handle on street tires, you're not going to be just looking for "mid 200s crank". That would be a total waste.
So in other words...
Build Motor, Add Boost & TURN IT UP!
BOOSTED wrote:250 crank? thats only about what 225ish wheels? i say go for about 250 whp, you gotta turbo man, turn that boost up, im goin for about 250whp in my gm charged and nitroused rebuilt engine.LOL great point guys. Now I'm really getting enthusiastic
LD9 Fury! wrote:NJHK (The Turbo Negro) wrote:LD9 Fury wrote:I'm don't think I'm going for crazy-high HP, just looking for maybe 230-250 @ crank turbocharged if I can pull it off. But you never know, everyone says boost is addicting so there's no telling where my HP will be once all is said and done
HAHAHA yeah right!
Build Motor, Add Boost & TURN IT UP!BOOSTED wrote:250 crank? thats only about what 225ish wheels? i say go for about 250 whp, you gotta turbo man, turn that boost up, im goin for about 250whp in my gm charged and nitroused rebuilt engine.LOL great point guys. Now I'm really getting enthusiastic
I'm sure my engine project will go fine no matter what I have to do, and it should allow me to run some fairly intense power... I'm more worried about this retarded-ass Isuzu 5-spd tranny taking a giant crap as soon as I feed lots of power.
NJHK (The Turbo Negro) wrote:It's times like this you wish you had the wonderful 4T40E 4-speed transmission, huh?LOL not in a million years! I'd have to wash myself with a belt sander if I ever owned an automatic car
LD9 Fury! wrote:NJHK (The Turbo Negro) wrote:It's times like this you wish you had the wonderful 4T40E 4-speed transmission, huh?LOL not in a million years! I'd have to wash myself with a belt sander if I ever owned an automatic carMaybe Getrag swap... may be even NVG-550 swap... bah I'd rather just buy an 03-05 Ecotec and start all over again before going through all that crap on my current car that barely squeezes a KBB value of $1500
just doesn't seem worth it...
Turbo as hard as I can until Isuzu tranny falls out of the car, then use that as an excuse to buy myself an 05 Sunfire
NJHK (The Turbo Negro) wrote:LOL! What can I say... I like the look of Sunfires a helluva lot more than cavaliers. At least when it comes to the 03-05 J's I like the 'Fire's more... cuz for the Pre-03 J's I like the Cavaliers better... Except for the 00-02 Headlights on the Cav's... I can't stand those. Maybe I'm just a weirdo... but that's how I see it.LD9 Fury! wrote:NJHK (The Turbo Negro) wrote:It's times like this you wish you had the wonderful 4T40E 4-speed transmission, huh?LOL not in a million years! I'd have to wash myself with a belt sander if I ever owned an automatic carMaybe Getrag swap... may be even NVG-550 swap... bah I'd rather just buy an 03-05 Ecotec and start all over again before going through all that crap on my current car that barely squeezes a KBB value of $1500
You would buy an 05 Sunfire just to be like me LOL
LD9 Fury! wrote:NJHK (The Turbo Negro) wrote:LOL! What can I say... I like the look of Sunfires a helluva lot more than cavaliers. At least when it comes to the 03-05 J's I like the 'Fire's more... cuz for the Pre-03 J's I like the Cavaliers better... Except for the 00-02 Headlights on the Cav's... I can't stand those. Maybe I'm just a weirdo... but that's how I see it.LD9 Fury! wrote:NJHK (The Turbo Negro) wrote:It's times like this you wish you had the wonderful 4T40E 4-speed transmission, huh?LOL not in a million years! I'd have to wash myself with a belt sander if I ever owned an automatic carMaybe Getrag swap... may be even NVG-550 swap... bah I'd rather just buy an 03-05 Ecotec and start all over again before going through all that crap on my current car that barely squeezes a KBB value of $1500
As far as being just like you, I don't think that would work out too well. "KYHK (The Turbo Cracker)" and " KYHK (The Turbo Honkey)" just doesn't have the same ring to it....
Da Turbo Cracka, perhaps???
Believe it or not, when I step back and look at the big picture, I don't have A LOT of money invested in my 2.4L Cav... I've always been more of an Eco fan since I first learned about them... I'm diggin' the Eco's growing aftermarket favoritism... so maybe there's an Eco Sunfire in my not-too-distant future...??
