suggestions before i start p&p - Performance Forum
Wednesday, February 22, 2006 1:25 PM
Well I just got my head back from being flow tested, for the "before" numbers
here are the numbers
now that i got the test done. i'm ready to start the port and polish on it.
Does anyone have any good helpful suggestions before I start? anything i should know so i don't eff something up?
This is for a 2200 btw.
Re: suggestions before i start p&p
Thursday, February 23, 2006 4:00 PM
well no one replied so i'll let you guys know how it turns out once i get it done and flow tested again
Thursday, February 23, 2006 5:41 PM
Don't try to match the exhaust ports to the header, use a stock 2200 exhaust gasket as a guid for port matching. Make sure the port on the head is slightly smaller than the gasket or header, about .025" on all sides will be good.
Reduce the valve guide in the runners to as close as reasonably possible to the runner's roof.
Match the bowl (the area just above the valve seat) to the valve seat. Be careful not to touch the valve seat with any cutters, stones or sanders.
Most of this is already covered in the SA Motorsports DIY Guide, but a couple of points I wanted noted.
Thursday, February 23, 2006 7:54 PM
MadJack wrote:Don't try to match the exhaust ports to the header, use a stock 2200 exhaust gasket as a guid for port matching. Make sure the port on the head is slightly smaller than the gasket or header, about .025" on all sides will be good.
i was planning on using the stock gasket, and i was also wondering about the lip on the exhaust...but you answered my question already ..thanks to you and OHV notec (who posted in the other thread) for the helpful tips
Friday, February 24, 2006 5:12 AM
http://www.sa-motorsports.com/diyport.shtm
you may have already seen this article but here it is anyway...its pretty helpful.
I have read a couple interesting things regarding porting that are not things you would just logically figure out. It is recommended to leave the exhaust port a little smaller on the bottom side of the port than the exhaust manifold in order to control reversion. The same is reccommended with the intake manifold, it must be slightly smaller on the bottom of the port than the intake port on the head. Just thought I would throw this out there for you.
02 LS Sport http://www.cardomain.com/ride/2135396
68 Firebird http://www.cardomain.com/ride/2135556
56 GMC http://www.cardomain.com/ride/2135587
66 Suburban http://www.cardomain.com/ride/2135589
