Oil Temperature gauge/Questions - Performance Forum
Friday, March 10, 2006 9:13 AM
I'm looking for people who have them. More so on a LD9. What temperature does the oil run at? I'm wanting to get one, but have no clue what temperature range our oil is at. Thanks for any info.
Re: Oil Temperature gauge/Questions
Friday, March 10, 2006 1:52 PM
I got one of these gauges too, wondering the same thing here...
I've had it for some time, looking on the Org for the same info + where to hook it up
into/at on the engine...
Sorry I cant help at this time.....
<---<<<Check Out The Ride!
Friday, March 10, 2006 3:11 PM
SiLvEr StRiPeY 04 wrote:I got one of these gauges too, wondering the same thing here...
As far as mounting it I'm not too concerned. I was thinking either in the oil pan (there is a location on the bottom that some years has a oil level sensor (my 96 has one, but my 01 does not but has the spot for it). I know there is a oil jacket on the back of the block as well. I could always make a t fitting for my oil pressure gauge sending unit and put it there as well. I'm wanting to know which gauge I should get (psi reading wise).
Friday, March 10, 2006 3:20 PM
Thanks for the info....I guess were both in the same boat!
Saturday, March 11, 2006 2:03 PM
Approx 80 - 130 degs more than your engine coolant.
Thats Him Officer The WICKED One.
Tuesday, September 04, 2007 12:17 PM
Just wondering if any LD9 owners mounted this temp gauge from anywhere else than the back of the block or the oil pan? Or are those 2 places the only locations?
Tuesday, September 04, 2007 12:54 PM
WHITECAVY wrote:Just wondering if any LD9 owners mounted this temp gauge from anywhere else than the back of the block or the oil pan? Or are those 2 places the only locations?
I did the back of the block. Works great there.
Saturday, September 08, 2007 5:57 AM
Would you happen to have a picture of which port you used?
Saturday, September 08, 2007 6:31 AM
mine is in the oil cooler adapter..no sense in having a temp gauge if you cant do anything about it
Tuesday, December 18, 2007 1:31 PM
BUMP. wondering what the average oil temp is on an LD9.
Portage, MI
Tuesday, December 18, 2007 5:26 PM
Seems to be 180-200. Has to be very hot days here in FL and highway driving to get close to 210
Tuesday, December 18, 2007 7:00 PM
i have one as well not hooked up yet thinking about doing an oil cooler as well
Don't you bottom out?
- Yes I do
Tuesday, December 18, 2007 8:17 PM
So, all I need to do tee off my oil pressure gauge coming out of the cam tower, to hook the Oil Temp gauge to?
Portage, MI
Tuesday, December 18, 2007 9:19 PM
-ruen- wrote:So, all I need to do tee off my oil pressure gauge coming out of the cam tower, to hook the Oil Temp gauge to?
I'm not so sure I would do that. You want the temp sending unit as close to the motor as possible, so heat is not lost. Put it in the block (easy to do).
