msd launch control setup - Performance Forum
Friday, March 24, 2006 1:34 PM
ok well i did a search and didnt find what i was looking for, i just picked up an msd dis2 from a member on here and i wanna know how ot setup the launch control, not on the pins but what wire to use and how to wire it up, i searched on google and came up empty aswell, maybe somoen can shine some light on this, thnks
parting out my built and boosted 97 z24 so4x4.com/cavy.html for pics and a parts list
Re: msd launch control setup
Friday, March 24, 2006 1:51 PM
I believe you just ground the launch control wire, and set the pins for the desired rpm. Flip the switch (or put it on the brake peddle) and it limits the rpms.
SPD RCR Z - '02 Z24 420whp
SLO GOAT - '04 GTO 305whp
W41 BOI - '78 Buick Opel Isuzu W41 Swap
Friday, March 24, 2006 2:27 PM
so a switch going to a ground then, makes sense, now heres the other question, what wire is for launch control? lol
Friday, March 24, 2006 4:35 PM
just a bump
Friday, March 24, 2006 7:11 PM
If it is the programmable DIS-2 then it looks like it should be the DARK BLUE wire according to http://www.msdignition.com/pdf/6212_frm%2024841.pdf
New sig in the works.
Friday, March 24, 2006 9:32 PM
pn 6211, found it in there, thanks alot man
Saturday, March 25, 2006 1:09 AM
I have it, just not hooked up..... was going to use the clutch safety switch, since I dont really need it.......
Saturday, March 25, 2006 2:04 PM
the only problem i can see form using somehting like the clutch safety switch is that if your like me and you wot swift itll drop your rpms down, unless you use a master arm like on a nitrous system and turn the launch control off after you get moving
Saturday, March 25, 2006 2:20 PM
You put the momentary on the clutch pedal and the power to a button on the steering wheel. THe button is the power and the pedal is the toggle. Without the button being pushed nothing happens.
That's how mine will be set...or just run it all off the button.
5K PB: 24:50
10K PB: 54:26
