double check for me before I start it up... - Performance Forum
Thursday, April 13, 2006 12:01 PM
Ok I think I have everything right as far as the lines go. I made a little diagram to show what everything is and to show the one questions I still have. Check out the pics and let me know. The green arrow leading to the nipple on the back is what I am not sure about.
That nipple is what I think I have to just plug is that right?
Re: double check for me before I start it up...
Thursday, April 13, 2006 12:20 PM
looks good to me
Thursday, April 13, 2006 12:23 PM
looks good so just block off that nipple and then its done?
Thursday, April 13, 2006 12:29 PM
yea block that off. Your good. I take it you found that line (the one thats white on my car)
Click the banner to enter the best Quad4 & Twin Cam site on the internet.
Thursday, April 13, 2006 12:33 PM
haha I had it the whole time but on my car its white from the firewall and then about a foot later it's connected to a black one thats what messed me up.
I just wanna say thanx alot to all of you that have helped me through my first engine mod.
Now hopefully it starts and works fine I'll let ya know my new intake is on its way.
Oh one other thing if I start it up without the intake will it mess up like I just want to test it. Or do I have to wait for the intake?
Thursday, April 13, 2006 3:10 PM
Where does the breather filter hose hook up to? I'm doing the swap and I'm not sure where that goes. Thanks.
"Kneel before ZOD!!!"
Thursday, April 13, 2006 11:03 PM
right under the second runner in the manifold there are two holes. The one on the left is for the hose that comes off the side of the fuel rail. The second you hook up a huse and then attatch that breather filter. If you have anymore questions feel free to email me as I can now help.
Thursday, April 13, 2006 11:09 PM
lol , thought you said you had that 1 plugged off already
lol
yes plug the 1 off in the 2nd pic
Thursday, April 13, 2006 11:12 PM
wut u doing bout ur egr? after the block off, but wut u doing to make sure u dont get codes?
Thursday, April 13, 2006 11:33 PM
i have a ZZ Performance EGR simulator if you wanna buy it..email me at mattbeck16@gmail.com ill give you a good deal
Friday, April 14, 2006 12:48 AM
HPTuners = remove trouble codes no more EGR sims..... no more O2 sims......
Oh yea, you have it right....... I usually have the MAP sensor hooked to the back port, and the front one plugged.... but its all up to you.
SPD RCR Z - '02 Z24 420whp
SLO GOAT - '04 GTO 305whp
W41 BOI - '78 Buick Opel Isuzu W41 Swap
Friday, April 14, 2006 6:02 AM
I hooked up my MAP sensor to the second hole on the mainfold. Is that suppost to go somewhere else? The only other hole I have open is the one in that second pic above on the back of the manifold. That is where I thought you had to hook up the breather filter. Let me know if I hooked this up wrong because I will mbe working on it today.
Friday, April 14, 2006 8:39 AM
so where can u find an egr simulator? and the hptuners u mentioned, that would mean clearing code every time u start it up
Friday, April 14, 2006 8:50 AM
Good job glad to see it's almost done.
One suggestion.. tuck that breather filter under the runners.. Although it's highly unlikely you'll ever be asked to pop your hood.. your car's slightly more modified than most (especially in T-Bay as you said) so you might get harassed a bit more, and the PCV is supposed to be a closed loop system.. so having that breather filter in plain view isn't a good thing. $300-365 ticket in Ontario if it's noticed
15.69@86.670 - stock 99Z
Friday, April 14, 2006 11:09 AM
I've been pulled over tons of times and never had them asm me to pop the hood.
How much is the tuners software, and how much is this erg simulator? never heard of it. How does it work?
As for the MAP sensor its fine where you have it just plug the hole on the back of the manifold.
I started the car today and it ran perfect. So I know what I did and that its all right now.
As for the codes I really could care less just curious about the simulator
Friday, April 14, 2006 11:42 AM
hp tuners is 650.00 for the top set up , and the 1 ill be getting
the egr sim some people have had issues with , jake being the 1 i know of
id recomend the hp tuners over the sim , because you can tune the car with it , and get the most out of all the mods your doing
Friday, April 14, 2006 1:04 PM
haha well how hard is it to tune I mean I don't really have any engine mods but it is something I would look to in the future.. Is it more for a turbo setup or is it good for N/A as well?
Friday, April 14, 2006 1:06 PM
When I started the car up it ran perfect it makes more of a whistle noise under the hood but I think thats normal if not let me know.
I know all the vaccum lines are fine cause it didn't rev right high.
The problem it has and that it had before is that when I rev it a bit and it comes back down to idle sometimes its a little rough and sometimes it will dip low in the RPM range. I dunno if its my o2 sensor cause I remember reading that that would throw a code.
Any other guesses?
Friday, April 14, 2006 1:33 PM
uhh...where does the other end of the brake booster hose go? It seems to be running towards the other side of the manifold, when it should be running towards the firewall. What'd you do with the metal hose/pipe that was connected to the brake booster port on your old Throttle body?
Friday, April 14, 2006 7:08 PM
so even with the egr code ur car is still running fine? wut kind of gains did u notice...was it worth the effort? thanks
Friday, April 14, 2006 9:56 PM
i have an EGR SIMulator that ill sell to you for 50 shipped..its somethin to use untill you can get the HPTuners... email me at mattbeck16@gmail.com
btw...brand new is 70+shipping
^^^^^ and mine is brand new... i never used it
Saturday, April 15, 2006 12:02 AM
the brake booster the old one i ripped to shreds I just ran a new one around the head and under the manifold
