Ive kinda tried to search for some stuff about making one, but i can really find much. should i use tube or PVC pipe?? what diameter should it be?? and how should i secure it to my TB? it cannot be that hard, cant be any harder than fitting a body kit
i kinda wanna use tubing, were should i get it from? i really dont want to order it online, can i get it at home depot??
I bought a 2 foot piece of 2 1/2" exhaust pipe, painted it used parts of the old intake rubber pipe and hooked strait on the throttle body put an oil breather in use the old iat sensor rubber flange and do a hold for it but a reactive tornado style filter an thats how i did mine for my 2200
how did you hook it to the TB? do you have pics? is there any specs on what the diameter should be
ahh.......i dunno. does anyone have a suggestion on the type of tubing that i should use?
id use some pvc piping since you can buy all sorts of bends and such, secure it to the TB with a rubber elbow with a hose clamp.
wouldn't with pvc or abs, you might be huffing fumes when your engine warms up, i can't imagine that its good for you so i would just get some aluminum pipe and see one done properly (made from a respected company) and form it as you see fit, still cheaper then buying one from a dealer.
99 Sunfire 2.2 5spd
Many people just buy an aluminum intake kit off of E-Bay, then get a K&N filter to replace the cheap filter that comes with those kits. Most should come with all that you need to install it in the car.
if your have a pep boys or i think auto zone might have it. they have custom bends to make your own intake they have 90' to 45' bends, an diff length tubes. and silicone to conect your tb to the intake or to conect other intake tubes together.
MadJack wrote:Many people just buy an aluminum intake kit off of E-Bay, then get a K&N filter to replace the cheap filter that comes with those kits. Most should come with all that you need to install it in the car.
Case in point:
Cheap eBay intake. Works like a charm.
what size is my tb?? i have a 2002 2200........
For mounting? I used a 3"-2.75" silicone reducer, but a 3"-3" would work too. Mine was quite a stretch to get it around the TB inlet.
abs shouldnt give off fumes. i think the ice man intakes for the 2.4's are abs.
think about. the 2.4 has a plastic intake manifold....no fumes...totally safe.
but i could be wrong also.
Dark for fear of failure
An inner gloom as wide as an eye and fermenting
Roiling hate
Death gripped my veins
Unveiling rancid petals
Flowering forth foul nectar
The space between a blink and a tear
Death blooms.-mudvayne
Roiling hate
^^^^^oops my bad
Roiling hate
leave the pvc for plumbing. i could hook ya up. mine is 3' od aluminum and rubber connectors. just shot me an email
streetfighterz wrote:abs shouldnt give off fumes. i think the ice man intakes for the 2.4's are abs.
ABS and PVC are two different types of plastic.
i bought a 3" intake from some guy in classifieds for 30 bux...works just fine and looks good.
this useless post brought to you by the alcoholic known as LUNDiS
i had a 3 inch pipe bent at midas and powedercoated at a friends. cheap filter and done
So how did the coating work out for ya? I've got a stove sitting in the garage. It's the one that was in the house when I bought it and I don't care what happens to it. I was kind of thinking about getting one of those DIY kits and doing my intake and a few other things. Then I can just bake the parts right in my garage and save myself some money. Might as well use the oven for something.
anyone make a intake for a ecotec i really dont feel like spending 200 dolla for a god damn pipe
