stevefire wrote:The true gain is in the roller tip and roller fulcrum rockers which decrease the rotational mass on the engine.Close. A major portion of the gain comes from having a roller fulcrum (roller tip really doesn't do much) on the 2.2L, but the 2200 comes with this stock. Also, it reduces friction, not neccessarily mass.
rawkfist wrote:WEll im creating this thread basicly to get some research and to hopefully get some questions answered... please dont flam!There's no flaming in OHV posts
rawkfist wrote:Well first of all i have a 1999 OHV automatic cavalier. It sadly has only a cold air intake, and a replacement muffler. All stock headers, cat, and tubing.We've all been there, congratulations on not giving up already lol.
rawkfist wrote:In hopefully a year or so i plan on getting a full custom exhaust , paecesetter polished header, high flow cat, resonator, 2.25" tubing and a oval magnaflow muffler with tip. This i know will help out my bottom end power.As Steve said, this will not help your bottom end, it will actually be detrimental to it. However, HP lies in high rpm, so power down low will have to be sacrificed (you can't have it all with NA small displacement motors). Also, a polished pacesetter header will rust through in a week lol, you want the coated version. If you want polished, buy from a company that uses stainless steel.
rawkfist wrote:This is what i have in mind for my car! 200 if possible N/A engine!I'm hoping this is at the crank and not the wheels? 200whp could be done, but the car may not be extremely 'street-friendly' in the end...
rawkfist wrote:As of now im looking into what does what with the head! So fare i understand valves, springs, Patriat PnP header, valve guides, and thats about it for the valve train. Now i read 2 or 3 threads about the head ... Soem people say the stuff on Jbodyperformance such as the 1.6:1 roller rockers will hurt my performance but then a different one contredits it by saying it will help with it. So are they good or bad? any tips or anything that can help me out here?Instead of going in to it in great depth, I'm just going to suggest staying away from BJP products. They have shown some quality-control issues in the past, and off-the-shelf parts they combine have had some complications. Besides, anything they sell can be had elsewhere, and for a LOT less $$$. The reason you're getting conflicting results on whether certain rockers will free up some hp is because the two different versions of the LN2 have very different rockers stock. The pre-98 had el-cheapo stamped 1.5 rockers, while the 98+ had a roller fulcrum with a higher ratio. This means that the earlier motors will benefit from anything else, but the 2200 has higher restrictions. First, you don't want to downgrade to the 'Magnum' rockers (like offered from JBP), as your will have increased friction at the fulcrum, reducing your power. Also, going to 1.5:1 ratio (unless it is accompanied b a proper cam) will reduce your valve lift and VE. So, the 2200 pretty much has no other choice but a full-roller, self-guided, 1.6 setup. This will give lower friction, higher lift, and a more accurate ratio (something the stockers lack).
rawkfist wrote:Also about the head ... i read the rockers adjustmant for my engine ... if i do this and tighten them down more ... will i get a little more power? will i need to get better plugs due to im running rich already? i dont know the AFR as of now but i know for a fact im running rich because of the left of gas smell.NO! DO NOT TIGHTEN THEM DOWN MORE!!!!! This will cause your valves to stay open AT ALL TIMES, and will KILL your power output (aftermarket rockers only). Your plugs will be determined by other factors, like quality of gas and ignition timing, don't worry about them until the very end. If you smell gas, you probably either have a leak or a fried catalytic converter. Your engine does run rich at higher RPM, but I've never smelled it really...
rawkfist wrote:So with the push rods ... ive read things about having push rods to long with to long of a stroke and the end product is having a valve hit the piston top. Do i need to upgrade these? what should i look into? i plan on getting 10.5:1 compression pistons to as high as 12:1 pistons.I'll skip the pushrod section, as Steve covered it already, except that I have to add, too much lift causes valve-piston intereference, proper adjustment with any pushrod will not cause what you said.
rawkfist wrote:Also high revolustion lifters... Needed? will i need them if i get a different cam? these are the most confussing to me!Like Steve said, slow's found a solution to this, although with stock springs and rev-limiter the stock lifters are fine.
rawkfist wrote:ok sence i mentioned the cam before ... should i get a specific grind/lifing cam? i see a stage two cam on jbodyperformance for 315 bucks. Any good or not worth the mod?Send in your stock cam to be reground by Crane. MadJAck has posted good info on reccomended specific grinds, look around for one of those posts. You'll probably end up with either his grind or mine.
rawkfist wrote:iknow i need new vlaves ... would getting 1mm oversized valves help me or hurt me?More airflow=help. Also, the undercut stainless material will decrease stem wear and increase airflow.
rawkfist wrote:with all of these mods will i be lucky if i get 200hp with proper tunning from Hptuners?From what we've seen from the few engines that have gone through a similar process, it could be close. There are other things that have to be worked out, like oiling, and specifics like your cam grind will have different effects.
in the head you have the cam ... all spinning from the timming chain from the crank. Now from there the lifters actually make contact with the rotating cam... thus puching the roller rockers, which push the push rods which push the valves. And as the cam roatates to close the valves the springs bring it back and then on and on. Is this right? if not please correct!
compression related ... now this is really something i need to know ... seeing as how im getting higher lift cam grind, higher compression pistons, and i want to shave the head .010 and get a thiner gasket ... will i need to worry about piston valve contact? if i shaved the head and got thinner gasket will it give me more power or will it be pointless? im kind of the guy that wants to know if there will be a gain and if not i wont do it because something might go wrong. please help on this!
sorry if none of this makes sence I think its like the lawn mower engine were on the crank gear there is a dot and on the cam gear there is a dot and you make sure those are right. maybe there not and again this is why im asking questions
Now with all of this said and done will i need to upgrade fuel? such as like running premium compared to my unleaded now? will i be able to stay at this level? does any one know what the octane of unleaded gas is? if no answer i will ask people at my wok (i work at a gas station) and at my dads shop.
stevefire wrote:oh myYou took the words right out of my mouth (I actually said it out loud...multiple times). I could have sworn we had answered a few of those questions...and there were a few that just...ugh. You work at a gasoline station, but you don't know how gasoline ratings work? Also, I know it sounds picky (but my head hurts right now), use the spell check function, or at least double-check what you've written. It's not bad when posts are only a couple lines, but reading through all that is actually painful.
