4-2-1 or 4-1 header? whats better - Performance Forum
Tuesday, June 20, 2006 9:09 PM
Ok so ive heard to go both ways? idk wats better a 4-2-1 or a 4-1? im leaning 4-1...... (i have a 2002 sunfire ln2 motor) I am currently under going a new exhaust with 2.25 piping and high flow cat. So ne suggestions?
Re: 4-2-1 or 4-1 header? whats better
Wednesday, June 21, 2006 12:00 AM
since you have the ohv motor , the long tube header like pacesetters is a good allaround header
long tube style 4-1 have the top end , and also have the mid to keep up with the most 4-2-1
Wednesday, June 21, 2006 12:04 AM
The difference in the end will be minimal honestly. It seems the 4-1's are a lot easier to come by for the OHV.
The 4-2-1 header will tend to give you a bit more low end power than the 4-1 header will - with the 4-1 you will see the gains more in the upper-mid RPM's and higher. Some people believe that the 4-2-1 is better for a daily driver since you're using that low end quite often. Others say that since it's a 4 cylinder engine, you're not going to see all that much low end regardless so you might as well beef up the range where the engine has a better chance to make power - the higher RPMs. But like I said...you may not really notice all that much difference between the two. Either one will be an improvement.
Wednesday, June 21, 2006 6:40 PM
4-1 makes more power in the upper end of the powerband
4-2-1 makes more power at the lower end of the powerband.
Friday, June 23, 2006 8:16 AM
Dude your sig is weird^^^^^
Friday, June 23, 2006 8:24 AM
Eric Garvock wrote:Dude your sig is weird^^^^^
I thought the same thing. Mario can't jump in mid-air.
Saturday, June 24, 2006 7:37 PM
Is this Pacesetter a 4 -2 -1 header? looks like unless thats just purely cosmetic.
Saturday, June 24, 2006 7:42 PM
No that shound be a 4-2-1 but idk about being a pacesetter
