taking off rusty bolts (help) - Performance Forum
Tuesday, July 04, 2006 9:46 AM
I am trying to get the exhaust off for the turbo and I cant seem to break the bolts hold. Ive tried every kind of rust remover...nothing. does any one know of a way to get them off. thanks guys much appreciated.
"boobs now with Riboflabin"
Re: taking off rusty bolts (help)
Tuesday, July 04, 2006 10:24 AM
Try to apply some heat with a butane torch, and rap the nuts/bolts with a hammer.
Don't forget to use antiseize when reassembling.
Project S-Bird
Tuesday, July 04, 2006 10:46 AM
pb rust buster , let it sit and soak it several times
and run the car so its warm then spray them again , then pull them
Tuesday, July 04, 2006 10:49 AM
use a impact gun if your not already, if worse comes to worse youll have to break the bolts with it.
Tuesday, July 04, 2006 12:00 PM
Dont use the impact until you try PB rust remover then heat,
Try the PB rust remover, several applications, if that doesn't work add heat with a blow torch, then try impact on them, otherwise your going to have to pull the damn motor most likely to get those bolts tapped out and thats a royal PITA!
Tuesday, July 04, 2006 12:05 PM
Use a piece of pipe to lengthen your wrench. Leverage is your friend. Soak it with PB Blaster, let it sit for a while, then use your lengthened wrench to get it done.
Tuesday, July 04, 2006 5:25 PM
its so werid. I never new about PB buster. I went to advanced auto and that was the first thing they recomended.
so far I have two off one had the head sheered off, and the other came undone. I have one more that Im just soaking and soaking. Im going to get it tommorow.
I do want to point out a good point. the bolts after the cat are only threaded to a certain point. so even if the head of the bolt comes off, you can take it apart. thanks guys.
consider this a bit of a pre warning. keep an eye out in the boost section. Ive been taking video pics and anything that will record.
