I was just wondering if a srt4 fuel pump would work in a 2000 Z24. I know that it wont be a direct fit but is there a way I can make it work. My fuel pump die on me and they are giving me a free srt4 fuel pump. thanks guys
It would take some fabrication work. You're better off getting a Cav OEM pump, or for higher flow, go w/ a Chev Blazer (which is direct bolt)
questions about that blazer pump, I saw something about that a while ago, and can't remember exactly what is was... how many LPH is that? our stock (2.4) is 70lph ish
and what years were they from, I searched and couldn't find anything
the blazer pump flows @ 188LPH, it from the early 90's blazers, not exact.
The SRT-4 is a 190LPH Walbro, if it will fit or not you'd be the first to find out.
I should seriously remove my walboro 255 lph, and get one of those blazer pumps, I need the fuel tank on my car. I did some highway driving and I had to refuel every 500 km's
ge_forcez22 wrote:I should seriously remove my walboro 255 lph, and get one of those blazer pumps, I need the fuel tank on my car. I did some highway driving and I had to refuel every 500 km's
why would that have anything to do with the fuel pump? we have return systems
I have no idea, lots of guys do the mod where they cut the cup but I really don't wanna cut it
But as someone seen a srt pump and compare them?
