HELP: why a CEL when i use my air/fuel gauge? - Performance Forum
Friday, October 06, 2006 1:26 AM
so i hooked up my air/fuel gauge a few weeks ago. on a cold start my car idles funny, which ive heard is normal. after a minute or less the idle is fine and it drives fine.
then a few days ago my CEL (check engine light) came on and my car was idleing a little more wierd then usual. i unhooked the air/fuel gauge and returned the setup to stock, and have had no idle or CEL problems since.
can anyone explain what is going on? my car is a 98 z24 w/ manual 2.4L LD9
thanks!
P.S. just so you know, i ran the wire from the AF gauge between the ECU and the o2 sensor, on the o2 sensor side.
- Cameron (CaliforniaCavalier)
- www.csc-motorsports.com (my new NOR-CAL car club site!)
Re: HELP: why a CEL when i use my air/fuel gauge?
Friday, October 06, 2006 2:38 AM
Bad connection of your air fuel??? If it's not hooked up correctly the ecu may recieve a falsed signal caused by a resistance!! It's why I can think of right now!!!
Friday, October 06, 2006 2:39 AM
replace why by what.... oops
Friday, October 06, 2006 7:22 AM
Are you using a wide-band sensor? If so, there should be a narrow-band output on the controller that scales the signal down for the ECU - make sure that's what you use for teh ECU. If you feed a wide-band signal to the ECU it'll run fine as long as it can recognize the signal but the first time the voltage out of the ECU's program, it'll look at it like and try to correct it when there's really nothing wrong. Could explain why the car is running like the poo...
Edited 1 time(s). Last edited Friday, October 06, 2006 7:26 AM
Friday, October 06, 2006 9:02 AM
common issues with basic a/f gauges
plus some computers seam to be a little more picky than others
best is to add another o2 sensor for dedicated use with the a/f gauge , or just use a wide band set up
Friday, October 06, 2006 9:15 PM
wide band is a little too much for what i want to do right now.
i might set up a dedicated o2 sensor but i dont know.
thanks for the replies.
Saturday, October 07, 2006 12:35 AM
nice thing with a dedicated o2 for the a/f gauge , it will give you a bung for the wide band
but i do recomend using putting the sensor in the down pipe just before the cat
