I was wondering if anyone can tell me the original specs for a 2200 in 1999 I want to know
Rocker Ratio:
Compression Ratio:
Valve Diameter:
Cam Specs:
bore:
Stroke:
'99 2.2 OHV w/3spd auto (work in progress)
http://www.cardomain.com/ride/2322134
ny-jbodies.org library
however, rocker ratio has been measured to be 1.54, not 1.6
fortune cookie say:
Anywhere to find this information now?? The website is no longer availible. This is proof i searched
www.bradsairsoft.com
I'm curious as to all these specs, too. And the one's for the '94-'97 LN2 while we're at it.
Go beyond the "bolt-on".
I have the 98+ LN2 file from the website saved on my computer(saved it cuz I figured it would be gone sooner or later), shoot me an e-mail and I'll send it to u. d356bud@yahoo.com
<img src="http://ad.nicoclub.com/banners/nico-banner1.gif" ></a>
There was a thread on here somewhere posted by tabs not long ago that had everything you would want to know.
Found this, not completely what you were looking for, but has a lot of good information about the engine in its different stages.
Here
i have a PDF file that covers the entire 2200. Send me an email and I will forward it to you. xxjazerxx@yahoo.com.
Thanks Notec! Now I just need the same layout of specs (specifically the factory cam) for the pre-'98 LN2.
Thanks notec very useful I have been looking for some of that info. Now I just need to find the same thing for a 2.4.
ZOMBIE THREAD!!!!!!! BRRRAAAAAIIIIINNNNNNNNS!!!!!
Anyways, I need specs too and both links in this thread are dead and Google isnt getting me anywhere. Does anyone have them?
do you wnat them? I can probably hunt them down here over the weekend....umm if you have a chilton's an older one they have the full spec out of it
Rocker Ratio: 1.6 (or 1.54)
Compression Ratio: 9.0 : 1
Valve Diameter: ???
Cam Specs:
Duration @ 0.050": 185*/185*
Intake Centerline: 108* ATDC
Lobe Separation Angle: 112*
Lobe Lift: 0.263"/0.263"
Lift @ Valve: 0.421"/0.421" (with cast steel needle bearing fulcrum, self-aligning rocker arms with a nominal 1.6:1 ratio. Some have been checked to an actual 1.54:1 ratio)
bore: 88mm
Stroke: 89mm
I took the cam specs off a thread from s10 forum that Mad Jack posted
______
Inochi
Thanks man. That helps with my cam questions. I still need stuff like port size. Maybe a flow bench of a stock head. Im curious about cfm and valve sizes and crap like that.
I couldn't find the valve sizes but I did find something on the valve ratio. I could go pull that back up again but I didn't find anything on the flow for the head.
______
Inochi
Balls. So how are all of you sizing turbos without flow info on the head and crap like that?
Awesome. Thanks!
Im gonna be reading all night.
