Plastic Gas Tank? - Performance Forum
Plastic Gas Tank?
Sunday, December 03, 2006 3:41 PM
i have a 1999 sunfire gt and it has the steel gas tank i noticed that in 2000 they upgraded to a plastic tank does anyone know if the mounting is different or if i can just order the 2000 and bolt it on?
Re: Plastic Gas Tank?
Sunday, December 03, 2006 3:46 PM
i beleive its still steel, with a plastic cover over it
Sunday, December 03, 2006 3:47 PM
They mount the same, but the plastic tanks have a extra line running from the front of the car back. Also the Evap system is mounted in the rear as well.
Sunday, December 03, 2006 4:13 PM
is it steel with plastic or an all plastic tank? can u mve the evap from the front to the rear or is it a new design?
Sunday, December 03, 2006 9:36 PM
im told that in 2000 they went to a plastic tank and yes they fit the same with the extra line.my 96 cavvy has the steel tank and in the midst or replacing the rotten one as well.
this is what the auto wreckers tell me anyway
Sunday, December 03, 2006 10:32 PM
steel tank is larger than the plastic tank
the plastic tank is all plastic
both fit in the same spot
Sunday, December 03, 2006 11:59 PM
^ werd.
95-99 tank is steel... 15.2 gallons (57.5 L)
00-05 tank is plastic... 14.1 gallons (53.4 L)
95-98 has a front-mounted EVAP canister and a vent line next to the fuel filler line by the gas cap. 99-05 has the EVAP canister mounted between the tank and the axle under the rear of the car. there is no vent line to the gas filler, but instead an EVAP line runs parallel to the fuel send & return lines to the engine bay.
The tanks are the same as the N-body tanks... my 2000 'vert has an 04 Alero tank in it, with a 00 Buick Park Avenue fuel pump
So 99 is a hybrid year... same fuel pump canister as all years, but the evap is on it, unlike the 95-98 design. And the level sensor changed in 2000, uses silver contacts which were recalled in most places for reading quarter tank when they were really empty... most 00 and 01 cars.
I think that's all the useless gas tank info I have in my head...
Monday, December 04, 2006 1:26 AM
Anyone know the weight difference between the two?
- 93 mph in the 1/8 mile
Member of J-Body Of Michigan.
Monday, December 04, 2006 12:05 PM
hold on 14.1 gals?..
Alright, add a new level sender to the christmas list, it shows empty after using 11 gallons. I don't think it has a built in 3 gal reserve, then again it does keep me from running dry...
Monday, December 04, 2006 1:10 PM
has anyone actually replaced a steel tank with the plastic tank
Monday, December 04, 2006 5:27 PM
i have on my 96.. it goes right in no problem
Monday, December 04, 2006 6:35 PM
All N 3rd and 4th gen and J body 3rd gen tanks mount the exact same way, just different sizes and whatnot. All gm car fuel pumps from the early 90s through now are the same fitments (different flow rates). I've got a 02 Grand Prix pump in my tank for instance.
Monday, December 04, 2006 11:36 PM
according to my 01 Z manual our cars have a 1.5 "reserve" Meaning our check gauges light "Fuel light" comes on when it thinks you have 1.5 gal left.
PSN ID: Phatchance249
Tuesday, December 05, 2006 9:19 AM
i'm interested in skillz question...does anybody know?
Tuesday, December 05, 2006 9:24 AM
Skilz10179 wrote:Anyone know the weight difference between the two?
No but I can find out. I have been planning to. We have one of each in storage. We just have not weighted them yet. Also the pre 2k fuel pumps and 2k+ are very different.
Tuesday, December 05, 2006 4:34 PM
alright sounds good can anyone teel me where to find it other than a gm dealership????
Tuesday, December 05, 2006 4:42 PM
yeah a junkyard.
Tuesday, December 05, 2006 4:46 PM
So the fuel pump from my '97 swap right into a 2k+ plastic tank from what I read. Awesome.
I stashed a tank from a 2001 Z24 in the interior of it, cause I meant to go back and pick it up replace my rusty steel one on the new '97!
Tuesday, December 05, 2006 9:39 PM
John Higgins wrote:Also the pre 2k fuel pumps and 2k+ are very different.
I meant that they will physically fit if you wanted to change from one to the other. That does not mean they have the same functionality.
Tuesday, December 05, 2006 9:53 PM
John Lenko wrote:^ werd.
that isnt exactly right john , the tank in my 97 ive filled with 16 gallons
and i thought the plastic 1 was closer to 12 gallons
Thursday, December 07, 2006 12:45 PM
no because in my 05 ive gotten 15 gallons in my tank and theres no way the piping holds 3 gallons
Thursday, December 07, 2006 1:27 PM
ive ran my 00 outta gas and it took just under 12 gallons to fill it
my 97 took 16 and i wasnt even out of gas yet , lol
15 gallons in a 00-05 id worry were the extra gas was going
Thursday, December 07, 2006 9:03 PM
Be careful if you use large exhaust piping and the plastic tank. If its too close it can melt it. Mine started to melt but I beefed up the heat shielding and it seems to be fine now.
Saturday, January 13, 2007 2:24 PM
Michael Hearn wrote:Be careful if you use large exhaust piping and the plastic tank. If its too close it can melt it. Mine started to melt but I beefed up the heat shielding and it seems to be fine now.
Yeah be REALLY careful on aftermarket exhuast pipes- my buddy just had this happen- melted a hole into the front of the gas tank, so now he has to replace it(and we cant find a new "plastic" one though, so we are going to have to use a steel one). Anyone have an idea how long it takes to switch one out?
Saturday, January 13, 2007 3:48 PM
[quote=97trd(???™)]
Tank = 15.2 G, plus filler neck you must have been very empty
