exhaust question - Performance Forum
exhaust question
Monday, December 18, 2006 12:57 PM
i have a hks carbon Ti muffler that has a 3in inlet and i dont want it to go to waste, there is a shop in the area that can bend 3in as well, and im planning to boost very soon, but one of my friends said " isnt 3in a little overkill even with a turbo??" well thats why im here, can the hahn stage 2 make full use of a 3in and what knid of power loss am i lookin at until i get boost??? i need help ASAP b/c if the 3in is gonna really kill my ponies then ill just use 2.5 and put a converter just before the muffler to go up to 3 but if its not gonna suck that bad then ill just suffer with a little less go until i get boost, not to mention i know skwirl has a 3in and he's N/A, i dunno please help and quick.
many changes in the making
my favorite part about doing bodywork,.......... bondo bugers
Re: exhaust question
Monday, December 18, 2006 1:35 PM
3" for N/A is overkill. I run 2.5" and even that is pushing it. 2.25" is more widely accepted as the perfect size for a relatively stock engine with jsut bolt-ons. Once you go boost, yeah 3" is great. The more you uncork the turbo the faster it'll spool and the happier it will be. I have an HKS muffler off a JDM Silvia exhaust that I had weld to my 2.5" with an expansion fitting and it's fine. That way I can use the same muffler when my turbo goes in, which will be 3" fromt he downpipe back.
Monday, December 18, 2006 2:07 PM
well what kind of power loss are we talkin here??
Monday, December 18, 2006 3:19 PM
It's not really power loss so much as it is a lack of torque. The engine will in all reality make the same amount of power, it jsut won't be able to use it. Running 3" pipe on this small of a motor N/A takes away a lot of exhaust velocity needed for scavenging and what not. It'd be about as bad as running the car open header. For a turbo it's fine because of how a turbo uses that exhaust energy. For N/A engines it's a different story. However, you can get away with 2.5" pipe with the engine the way it is now, and then keep the 2.5" when you go turbo. For a street car, even boosted, 2.5" would still work given the turbo is sized properly.
