Ok had another quick question... Would i have to get the axels specificly for an 04 getrag eco/tranny or would any 5 speed axles work?? Thanks again!
O and also i was lookin and the ones with abs are alot more whats the differance?
you need specific axles for your transmission
and the difference is the ABS reluctor ring on the outside of the axle
All 00-05 axles are the same, except for the ABS reluctor rings. You can heat up the ABS rings and move em to the other axles if you have to.
John Lenko wrote:All 00-05 axles are the same, except for the ABS reluctor rings. You can heat up the ABS rings and move em to the other axles if you have to.
Almost... manual for manual, auto for auto, you can't use auto axles on a 5 speed, and you can't use 5 speed axles on an auto. And all 95-05 5speed axles are the same, 95-05 auto axles are all the same, even though the books don't say they interchange, they do. I'm running a 97 2.2 5 speed passenger side axle in my 00 getrag 5 speed.
Durr... I should have specified manual or auto
but on that note... you need 4 speed auto axles for a 4 speed auto, and 3 speed auto axles for a 3 speed auto. They're different.
Awesome guys thanks! Now i must order 5 speed axels... Again thank you!
