New Header - Performance Forum
New Header
Wednesday, February 14, 2007 3:32 PM
I was reading previous posts on header installation. Many suggest getting performance engine mounts, but I hear a lot of people complaining about the vibration that comes from these. Will I be safe getting a piece of flexpipe? Also, would anyone suggest getting a new gasket for the header, or will their replacement (pacesetter) be good? Thanks.
Re: New Header
Wednesday, February 14, 2007 5:36 PM
some people go that route. i went with motor mounts myself. i can hardly tell they are there any more. you get used to them
some use the stock gasket that came with the car.
Re: New Header
Wednesday, February 14, 2007 6:51 PM
If you wanna get mounts Id go with a TTR upper cause people have felt less vibrations with it than the rksport upper. Also theres a gp goin on for it so you can save like $30. Then go with an rksport lower mount.
Re: New Header
Thursday, February 15, 2007 4:33 AM
i have the RK upper mount on my 04...havent noticed many bad vibes...however i took off the RK lower and went back to stock...it caused too many vibes (for my taste) when i had the AC on...whick is ever time i get in the car for about 5-6 months here in central Florida. if i lived somewhere where i little or never used to AC id have left it in place.
Join verbalwarfare.com
Re: New Header
Thursday, February 15, 2007 6:11 AM
I have the motor mounts and a flex joint. I recommend NOT doing the flex joint. It will allow the exhaust to sag, and adds a little rasp to the sound. As for the gasket, I do not like the one that comes with the header, and have always used the stock one. The stock one is a good gasket as long as it is not messed up.
Re: New Header
Thursday, February 15, 2007 6:24 AM
I'm thinking about buying the TTR upper mount and either the TTR or RK lower. I'll stick with the stock gasket as well. Thanks.
Re: New Header
Thursday, February 15, 2007 6:44 AM
Considering TTR does not make a lower mount, it may be difficult to buy. haha thanks for the info.
