anybody know what rod bearings would go good with my eagle rods?? i bought A.C.L. but i heard theytend to breakdown after a few thousand miles. are clevite good ???
hondas are like tampons.....every pu$$y needs one...
mildly built 99' ln2, eagle h-beam rods, wiseco forged alum. pistons, cusco oil catch, t3/t4 super 60 garret, tial 40 mm wastegate, hp tuners, prothane mount inserts, 2.5" exhaust.
Which motor are you putting in the car? I have the Clevite in my built 2.4.. But Clevite are good, regardless of engine..
right now its a 2.2lohv im planning on a turbo setup in mid spring then tuned a week or two after installing it!!!
2_low_4_fat_hoes wrote:right now its a 2.2lohv im planning on a turbo setup in mid spring then tuned a week or two after installing it!!!
I'd just like to point out that you must tune RIGHT AFTER putting the turbo on...it won't last a week or two, and I know that from experience.
fortune cookie say:
Anybody know where I can get the Clevite rod bearings for a 2.2/2200. And main bearings for the same motor thanks
NAPA
Are those going to hold up to boost applications?
Clevite 77 rod bearings part #CB745H - Howell Automotive has these cheap online
Clevite 77 main bearings part #MS-1704P
Clevite 77 full round cam bearings part #SH-1365S
These are the best bearings availible for our motors, but if you want even more protection you can have them cryotreated or coated.
fortune cookie say:
Not to thread jack but, I have the 2.4, and I'm going to rebuild my engine with the HO parts including 086 head. I will be using nitrous when all is said and done nothing past a 75 wet shot. Will I need to replace my bearing with the better clevite 77 bearings or would stock bearings work fine?
In the planning stage for an all American TRD Cavalier.
OHV notec wrote:Clevite 77 rod bearings part #CB745H - Howell Automotive has these cheap online
have the 2.4 part $ (main & rod ?). JBP wants WAYYYY TO MUCH.
My Cav
I give up...
