I am having a cam problem - Performance Forum
Sunday, March 11, 2007 5:41 PM
I have an HO cam setup on my LD9. I have been fighting with a MS-2 setup for 6 months now and I am ready to move on. Is there any reliable company out there where I can get an intake cam with cam position sensor with HO specs or does anyone know where I can get the sensor pad attached to the cam. I am really getting frustrated with not being able to drive the car. Any help would be greatly appricitated.
Re: I am having a cam problem
Sunday, March 11, 2007 8:59 PM
MSD Cam Sync Generator
give that a shot....... I believe its the one needed to fake a cam signal so you can run w/o the CPS pad on the OEM computer.
SPD RCR Z - '02 Z24 420whp
SLO GOAT - '04 GTO 305whp
W41 BOI - '78 Buick Opel Isuzu W41 Swap
Monday, March 12, 2007 3:52 AM
Has anyone you know of used it yet?
Monday, March 12, 2007 3:49 PM
SpeedRacerZ, do you think this system will work with cam sync gen? Do you know of anyone that has used it before?
Tuesday, March 13, 2007 8:16 AM
if I put up the right one, it should be the reason Protomec said the CPS pad is no longer needed....... I think there are a couple LD9 and Eco guys with it, just cant think of who at the moment.
Tuesday, March 13, 2007 10:54 AM
exterminator, rodimus prime, and QBE ran the cam-sync gen on their MSD setups
I'll be joining the list soon.. these are all ecotec guys tho
I think tony from CNFX may have ran the cam sync gen on the 330hp blue 2.4 beast, but I'm not sure and I don't want to put words in his mouth
Tuesday, March 13, 2007 3:58 PM
If any of you out there are using the Cam sync gen, I would like to know how it is working for you and can it be used on the a stock pcm.
Tuesday, March 13, 2007 5:13 PM
DaFlyinSkwirl (PJ) - BPU++ wrote:exterminator, rodimus prime, and QBE ran the cam-sync gen on their MSD setups
..to reiterate
i've personally seen, and ridden in these cars, and helped exterminator set his up (2.2 eco turbo) and the cam sync gen does work.
the eco ignition isn't too much different than the 2.4 ignition... and all of the above mentioned people have used it on the factory pcm/ dis2 msd setup
what exactly is your problem anyways, a CEL right?
MSD and the cam sync generator
^^check this out it may help
Tuesday, March 13, 2007 5:20 PM
I have a set of HO cams. Does it go on like the saturns and wrap around the #4 spark plug? I have been trying for 6months to get my Mega Squirt system work properly and it has been one headache after another. So I want to use the factory pcm and HP tuners.
