Hey anyone know the reluctor ring specs on the ld9.
more info might be helpfully... the reluctor ring for what?
dont go there dude.
Darkstars: the relutor ring is located on the front of the GM V8 motors. It is another version of the VSS sensor.
So what deos the cps read?
Reluctor ring = Middle of our crankshaft with notches on it for the CPS to read and the ecm to count for firing order.
Gilles
2.3 Ho
CHM wrote:dont go there dude.
WTF are you talking about?
You have no clue, do you?
sig not found
protomec wrote:CHM wrote:dont go there dude.
No hes right, disconnect your crank sensor, then see how fast you can get the car to go.
Last time I checked, the crank sensor is not on the transmission
the original poster did not specify which reluctor ring
Ok so does anyone know the specs on it or have a pix. And for the anal retentive guys by specs I mean how many notches and wheres the double notch at. A pix would be nice.
7 notches
six equal spaced with one doubled.
I do not know the indexing of them of the top of my head.
sig not found
taken from MSEFI.com.. they have alot of info about GM dis
I can get the specs from the one in the shop if you need em, and the ld9 has 5 notches I believe. That diagram is for the v6, and the v8 has 9 notches. In the other diagram on megasquirt, it shows the 4cyl notch locations.
hotbug1776 wrote:I can get the specs from the one in the shop if you need em, and the ld9 has 5 notches I believe. That diagram is for the v6, and the v8 has 9 notches. In the other diagram on megasquirt, it shows the 4cyl notch locations.
Yes please I would greatly appreciate that.
i thought all the cars have a 7x reluctor wheel.. i know my ecotec crank does..
4 cyl and V6 both use 7 notch wheels.
Wheel should be within .02" of sensor at all times. Runout must be kept to a minimum.
Width on older engines is generally at least 3/8" and as much as 1/2." I've built wheels as narrow as 1/4" and they seem to work fine. Wider wheels are less susceptible to runout issues.
This article shows pictures, says this:
1996 VIN T – The crank for the 2.4L engine has a longer stroke, narrower rod journals, a smaller, but wider reluctor wheel that has all the notches in different locations, and a chain sprocket for the balancer. It’s a 4620 casting."
Notches are 7 degrees across gap. Very important to correctly locate notches relative to TDC. Might want to locate a reman crank from a chain type parts store to make some measurements. Don't use info from older 2.3 engines, it may not be correct.
-->Slow
That article is wrong about the notches, only one is different than the 2.3L, we use the 2.4L crank for the 2.6L stroker and can do a RW mod to use the stock computer. The mod consists of filling and moving one notch on the 2.4L crank to match the 2.3L. The 2.3L had a larger RW but it was also narrower.
I guess I'll have to count my notches on the crank again LOL
The 4 cyl must ignore some pulses then to get the firing right.
Oh well, I'm going EDIS anyway, so I will have total control of my timing from now on.
hotbug1776 wrote:That article is wrong about the notches, only one is different than the 2.3L, we use the 2.4L crank for the 2.6L stroker and can do a RW mod to use the stock computer. The mod consists of filling and moving one notch on the 2.4L crank to match the 2.3L. The 2.3L had a larger RW but it was also narrower.
i have total control of my timing also
slowolej,
why are you so damn smart??
