I just threw on a catback exhaust tonite with my neighbors and when we got the car on the lift they said I need a new i believe it was a resinator and header and motor mounts. I was just wondering how much all of this will cost me in the end. Thanks in advance guys
-Joe
what engine and are you looking for aftermarket or stock parts that makes a difference
its a 1999 2.2, but I am just looking for something stable that wont ever break on me again. I dont want to go ridicolous with money just for the mounts but i dont want no $hit on my car either
I just paid $250 to get my 2 1/4 cat, 2 1/4 mid pipe with sensor mount, and 2 1/2 inch resonator done. I too was finishing up my catback which is 2 1/4.
I didnt do a header, or modify the exhaust manifold.
I dont know what the engine mounts will cost.
Wait for a cat back and what reason will you need a new header, mount and resonator.
I've had a cat back on both cars that I've had at some point and never needed those.I think your garage is trying to take you for a nice chunk of change!
Every aftermarket motor mount will recomend install with the exhaust header off, why? The header is very fragile and mounted in a stable way. When you install the engine mount, you may move and put stress on the header causing it to break. Joe said he needs a new engine mount. What probably happened is when the engine mounts wore they put stress on his header causing it to break.
Joe what ever you do, install the engine mounts first. If not, then you probably will break yet another header.
depending on your car, you can get a combo upper and lower mounts for $150-$200
Make sure you get the actuall mount, a upper mount insert is designed to support the stock mounts, in your case won't help much.
Aftermarket resonators can be bought used on ebay for probably like $50 minus shipping.
If your running a stock muffler, then i wouldn't even worry about fixing the broken one.
resonators are for comfort, it may make your car just a little louder.
I need these motor mounts asap, has anyone ever bought a set or can reccomend a pair because I really dont know that much about mounts.
get them from carcustoms.net
carcustoms.net FTMFW! karo is a cool a** dude. he'll be very helpful to your needs
