A/F Gauge Problems - Performance Forum
A/F Gauge Problems
Sunday, April 29, 2007 11:38 AM
I just hooked up my a/f gauge and the thing is going insane! i start the car and it runs fine but the gauge is reading all over the place. i disconnected my o2 sensor is there some kind of re-learn it goes through or what? i'm at a loss here any help would be gretaly appreciated.
We Ride Together, We Die Together...... J-Bodies For Life!
SPONSORED BY: Showstopper Tuning, JM Graphics
2003 Cavalier LS Sport "SHOCKWAVE"
Re: A/F Gauge Problems
Sunday, April 29, 2007 12:32 PM
its supposed to go back and forth
Sunday, April 29, 2007 1:56 PM
yepp. unless you have a wideband its supposed to do that. there only good to tell u if something is wrong with your car. thats it. other than that they dont read the most acurate.
Sunday, April 29, 2007 4:09 PM
so its supposed to bounce from lean to rich and back all the time?
Sunday, April 29, 2007 4:33 PM
Patrick Myers wrote:so its supposed to bounce from lean to rich and back all the time?
answer
99redz24 wrote:its supposed to go back and forth
its just a light show really
Sunday, April 29, 2007 4:51 PM
man that kinda blows
Sunday, April 29, 2007 5:48 PM
Patrick Myers wrote:man that kinda blows
researching a part before you buy it > you
Sunday, April 29, 2007 6:28 PM
well i saw other gauges and they stayed in a certain range not flicker all over i thought this would be like that.
Sunday, April 29, 2007 7:16 PM
You bought a glorified voltmeter...Companies get off on screwing those who aren't aware of this. They make bank in the same way AEM does with their flashy intakes. If it isn't a wideband, it's trash.
"Youth in Asia"...I don't see anything wrong with that.
Tuesday, May 01, 2007 5:33 PM
So then why do they even have a gauge like this if all it does is flash all the time and not give oput a proper reading? also I gforgot to mention I wired mine into the purple wire to the o2 sensor on the manifold. dunno if it makes a difference at all or not.
Tuesday, May 01, 2007 5:44 PM
It DOES help in certain cases. Its not like its bouncing all around because it WANTS to. I agree that its inaccurate to the degree that you DONT know EXACTLY what your a/f ratio is. However It is a good place to look if something is fishy with the car. Example the other day i was having issues, which was my fuel filter, the car would bog and cut out and lose power. every time it did it it went extremely lean.
If you whomp on the gas, itll peg rich.
I have one, but its a dial type, not lights. And its helped me out a few times. I wouldnt use it to tune the car or anything, just for reference.
To the people that say its trash, its really not trash, its just a monkey compared to a human when its placed next to a wideband.
But yes if youre car is running correctly, it should be bouncing back and forth.
its to make money off of people who look at it and go "Oh purdy lights"
if you want to monitor your A/F get a wideband 02 sensor and gauge
Tuesday, May 01, 2007 6:05 PM
but i don't have any tuner on it so a wide band wouldn't really do me much good would it?
Tuesday, May 01, 2007 6:13 PM
its still better than the one you got
Tuesday, May 01, 2007 6:17 PM
If it was me, I wouldnt get a wideband unless youre going to run n2o, or boost, or have a LOT of mods done to the motor and you are going to use it for tuning.
Otherwise Id spend the money on something else.
Tuesday, May 01, 2007 7:12 PM
i have a 3 gauge pod so i might just get an oil temp gauge for like 50 to fill the empty space no sense having a gauge that don't work
