2.3 manifold - Performance Forum
2.3 manifold
Tuesday, May 01, 2007 12:00 PM
i have a 2.3 lo manifold and i want to put it on my ecotec. has anybody done this? are there pics? help me out if you can.
Re: 2.3 manifold
Tuesday, May 01, 2007 12:42 PM
no and no. at least not that i know of
Chris Fontana was trying to get some intrest in making a flange for the eco like there is for the 2.4. but im not sure if that ever panned out
Re: 2.3 manifold
Tuesday, May 01, 2007 12:47 PM
There was one person, I thought he was french or something who had success with it. He was also turboed and it looked really good.
I was going to try and design a flange but due to lack of eco parts to go by it is hard. To be honest there will likely not be any flange made unless there is prove results that benefit from the swap. If I had an eco I would try it out, but I have the crappy quad.
2.3-2.4 HO ADAPTER FLANGES 65$ shipped, Check GP Forum!
Re: 2.3 manifold
Tuesday, May 01, 2007 4:09 PM
yeah, i remember seeing the pictures a long time ago before i decided to try it and now i cant find them. but i already have the manifold and i have a piece of phenolic to use for the adapter already, so i may go ahead and try it, but im going to do a little porting on the manifold itself to try and make the transition from 2.3 to eco as smooth as possible to the head. im going to try and start tonight, ill post pics if i get anything done.
Re: 2.3 manifold
Sunday, May 06, 2007 3:04 PM
ok heres the update, got some of the port work done.
heres some of the tools
heres what i started with
some of the porting
Re: 2.3 manifold
Sunday, May 06, 2007 3:13 PM
decent.....now if only i had an eco to go along with it......meh, LD9 tastes better
Re: 2.3 manifold
Monday, May 07, 2007 6:57 PM
yeah, its kind of rough right now, i havent finished polishing yet. and yeah, id be happy if it was running, right now it just sits waiting to be unleashed onto some unsuspecting civics and tegs in my club.
Re: 2.3 manifold
Tuesday, May 08, 2007 11:46 AM
WOW...i didnt think the 2 heads had port spacing that close, hell theyre almost identical except for the shape. ill have to look into doin this myself, seems like a better, and cheaper intake than the saab. but a question, i dont know much about the 2.3/2.4...exactly which engine is this off of, and what cars is it found in?
Join verbalwarfare.com
Re: 2.3 manifold
Tuesday, May 08, 2007 11:50 AM
oh, what TB are you gonna use?
Re: 2.3 manifold
Tuesday, May 08, 2007 3:56 PM
it is off of a 2.3 out of a grand am. i am going to use the stock eco throttle body because the two mount holes actually line up with the manifold.
Re: 2.3 manifold
Tuesday, May 08, 2007 5:56 PM
looks like only 2 of the flange bolt holes match up...are you gonna weld the Eco flange to the manifold, or are you gonna add some metal to the 2.3 manifold?
Re: 2.3 manifold
Tuesday, May 08, 2007 6:06 PM
also...ive seen that eco flange on ebay...but is there any other place to get one?
Re: 2.3 manifold
Tuesday, May 08, 2007 6:34 PM
i am making an adapter flange out of phenolic. the aluminum flange was just to get size and shape. level zero motorsports carries them. you can get them with or without oring cutouts.
Re: 2.3 manifold
Tuesday, May 08, 2007 10:18 PM
Not 2 familar with the ecotec engine even though my cousins friend has an alero with one, but is the intake manifold plastic like the quad 4? If not just just cut off the flange from your manifold and weld it on to the 2.3 manifold. But if not then I quess you would need that adapter flange.
GMR has got nothing on this
Re: 2.3 manifold
Wednesday, May 09, 2007 10:03 AM
yes the stock manifold is plastic. i would just port match it but i dont like the position of the tb.
Re: 2.3 manifold
Wednesday, May 09, 2007 10:18 AM
what up with these plastic bull@!#$ manifolds what was Japan thinking when they buit these engines the states
Re: 2.3 manifold
Wednesday, May 09, 2007 12:00 PM
DOHC_tuner wrote:what up with these plastic bull@!#$ manifolds what was Japan thinking when they buit these engines the states
The plastic does not hold in the heat like the metal ones. there is no real proof that the 2.
3 manifold is better.
Re: 2.3 manifold
Thursday, May 10, 2007 6:31 AM
Looking good, I may buy one of these flanges to try and make something work. How many bolts are going to be holding on the manifold, were you able to utilize all of them? I have little experience with the ecos, I need to get something to go by.
Chris
Re: 2.3 manifold
Thursday, May 10, 2007 9:22 AM
the four upper bolts will bolt the adapter to the manifold and the two lower will go through the manifold through the adapter and straight to the head, and the two outer and three upper on the adapter will bolt to the head
Re: 2.3 manifold
Thursday, May 10, 2007 9:34 AM
ok, i don't mean to thread jack but i didn't think there was a point in starting a new thread. which flows more, the HO or the RKSport 4-2-1?
Re: 2.3 manifold
Thursday, May 10, 2007 9:37 AM
this is for the intake mnai not exhaust
Re: 2.3 manifold
Thursday, May 10, 2007 11:33 AM
meh, doesn't matter, it's still a 2.3 manifold. fits the title so it really shouldn't matter. pluse, it's a simple question for anyone that knows. cuz if the rksport flows more then i'm gonna cut the flange off a HO and weld it to an rksport and put it on my 086 head swap job
Re: 2.3 manifold
Thursday, May 10, 2007 11:58 AM
Thrice . wrote:meh, doesn't matter, it's still a 2.3 manifold. fits the title so it really shouldn't matter. pluse, it's a simple question for anyone that knows. cuz if the rksport flows more then i'm gonna cut the flange off a HO and weld it to an rksport and put it on my 086 head swap job
not if the Ho exhaust manifold is cast iron your not, cause you cant weld cast iron to steel, and the RK header is steel. however, for the purpose of answering the question...hell yes the RK flows better, if OEM exhaust manifolds were worth a damn they wouldnt need to make headers.
Re: 2.3 manifold
Thursday, May 10, 2007 3:35 PM
of course the rk, its a header. headers are made to flow more air. the ports are better, and the runners are straighter and smoother than cast iron manifolds.
Re: 2.3 manifold
Thursday, May 10, 2007 8:36 PM
Completely steering off topic is one of my greatest JBO pet peeves...however, I feel it necessary to comment:
You are comparing a header designed for increased exhaust velocity on a head with smaller ports, valves and low lift cams to the 90-92 cast iron exhaust manifold which was engineered with a 7200 RPM redline in mind...and you are going to sit there and tell everyone that "because it is a header it must flow better than any stock manifold." That is complete ignorance bro. If you have ever looked at the HO exhaust manifold, it is quite massive and resembles a "shorty" 4-1 header.
"Youth in Asia"...I don't see anything wrong with that.
