I have 2002 cav 2.2 automatic. I run it at a circle track in 2nd gear. I hit the rev limiter 3/4 down the straightaway. I recently purchased a hp tuner kit and can't get it to work. I am tired of trying. I was wondering if i could just send my computer out of the car away to be programed and who could do it?
Do the z24 cavs have a sway bar?
why dont you just upshift????????
probably because of the size of the track. he probably is only in those high rpms for a short time before he comes to a turn. shifting up might lose more than he would gain. getting a couple hundred RPMs in the one gear he needs for the track, would make sense if he isnt staying in the high RPMs too long.
I have helped on sport-4 and little enduro cars before lol.
KevinP (Stabby McShankyou) wrote:not funny... i just can't find that funny... not with 2 copies of the Candyland board game on your shelf.
Andrew Graham wrote:I have 2002 cav 2.2 automatic. I run it at a circle track in 2nd gear. I hit the rev limiter 3/4 down the straightaway. I recently purchased a hp tuner kit and can't get it to work. I am tired of trying. I was wondering if i could just send my computer out of the car away to be programed and who could do it?
I told you in your last post about this the only person I know who can do it name was.
As for your "Do the z24 cavs have a sway bar?" it belongs in the suspension and brake forum.
I don't see it in the last post, can you give his name and number.
unless you have a built upper end raising it isnt a very good idea, those valve springs wont last long
is there a way to raise the netural rev limit it seems to peak out @ 3500 rpm not very impressive sounds like a cat choking on it's own vomit
^^^ Why do you need to rev the engine out in neutral? The answer is yes, but If you are going to be...
a) neutral dropping
or
b) revving it out to "look cool"
then I'm not about to tell you how.
"Youth in Asia"...I don't see anything wrong with that.
show us some pics of the car and im sure someone will tell you. i have never done it before so i dont know. i help a guy in our sport compact class he runs a 90 teg.
maybe not today, maybe not tomorrow....... but some day
well sorry for asking
both a and b
ans yes i know a is bad on the transmission
driving fast never killed anyone it was the sudden stop
97 chevy cavalier z24
james gilk wrote:is there a way to raise the netural rev limit it seems to peak out @ 3500 rpm not very impressive sounds like a cat choking on it's own vomit
why? you do realize there is a rev limit in netural for a reason.
what is that for and why is it set so low?
and is there any advantage of neutral dropping or does it jam the tranny and spin the wheels
Let me correct that last statment i do know the reason it's there it to prevent people from reving the engine and dropping it in gear
im soon th have a 5 speed swaped in and was just wondering if it was possible to raise it
I would like it to be at least another 1000 rpm higher it's not like i am attempting to do a neutral drop a 7000 rpm (4500 rpm would be nice)
james gilk wrote:Let me correct that last statment i do know the reason it's there it to prevent people from reving the engine and dropping it in gear
you realize thats not helping. the computer recognizes the rpms are too high and changes it to when it engages its not a HUGE neutral drop. and yes its pointless.
If you swap in a 5 speed, then the nuetral rev limiter will change. The rev limiter on 5 speeds are set to like 6000RPM, or whatever the safety point is.
I do not think the top end of the 2200 will like 7000RPMS. If you were only upping it a couple hundred fine. I can help you raise the rev limiter as well. Yes you can also raise the neutral rev limiter as well (never really understood the point in it actually).
im running a 2.4l dohc ld9 and i was using 7000rpm as a referance.
As said in a previous post James,really read all that this site has to offer before posting,that way when making a thread or posting in one you'll avoid the flaming and you might actually have some knowledge before asking questions,just trying to help you out.Trust me I made the same mistakes before but now I have at the least a small amount of knowledge about my own motor and vehicle.
im sorry i have read alot of other posts on here and i didn't realize there was a product called hp tuners.
just out of curicioty im going to be putting in a jetchip 180 degree thermostat will hp tuners allow me to control the temprature the fan will come on @
whats the factory 200-220 degrees i think?
I believe so but am not so sure,I am just doing the fan override mod that is in the library so I can turn the fan on whenever I want but my advice to you is if your 2.4 is stock right now,start out with the beginning stuff.Header,exhaust,intake,motor mounts,trans mounts,shift kit or short throw shifter(dunno if you have a manual or auto?)but start small unless you have the cash to go all out,then I'd say build the motor and boost it along with every bolt-on you can get.Good luck
I would stick with the stock temp thermostsat. Yes HPT can change the temps that the fans come on at and the temp they shut offf at.
DONT EVER.........E...E...EVER NUETRAL DROP YOUR CAR!!!! unless you like to replace your trannsmission
Seems like a dumb question but what is "neutral dropping" exactly?
Is it just when you rev it in neutral then suddenly pop it into gear?
And if it is the above then why the hell would anyone want to do that ?
