Anyone bought and assembled a FERREA valve train?? - Performance Forum
Friday, July 27, 2007 9:04 AM
Hello,
Just getting ready to place an order for a Ferrea valve train. I searched but came up with nothing.
Im going to buy valves and valve springs ..... but what else will I need?
Can I use the stock locks etc? Or what?
What did you guys use when you installed these valves? What stock components did you keep?
Thanks.
"Go Before Show Yo."
CARCUSTOMS.NET, THE BEST SERVICE ON THE ORG!!!
Re: Anyone bought and assembled a FERREA valve train??
Friday, July 27, 2007 10:39 AM
We sell many many of these sets.
The Valves work on the stock springs/retainers.
However, if you get the valve springs, you MUST get the Ferrea titanum retainers. The only other option, or upgrade, is to get "seat locators by Ferrea" which will increase the valve spring pressure, for high lift cams.
You will use the OEM keepers on any configeration.
We sell them at www.TurboTechRacing.com let us know we should have the lowest prices on them.
-Aaron
Friday, July 27, 2007 4:43 PM
I am going to be running the comp stage 3 NA grind on my car.... im also shooting to turn between 8500-9000 rpms.
At what point would I need the "seat locators" do you recommend them for the above set up?
Friday, July 27, 2007 4:45 PM
Also is there anyone here running the stock valves with Ferrea springs? If so what was your reasoning......?
Friday, July 27, 2007 5:50 PM
If you run the stage 2 comp cams we "reccommend" the upgraded spring/retainers/seat locators
If you run the stage 3 comp cams you MUST use the Ferrea dual spings/retainers/seat locators
Comp cams stage 1 works fine with the stock valve train.
-Aaron
Friday, July 27, 2007 6:26 PM
I don't see any Ferrea sets at Turbo Tech Racing.
Friday, July 27, 2007 6:31 PM
I don't see comp cams for the LD9 either
Friday, July 27, 2007 6:44 PM
How can you turn off the rev-limiter ont he LD9, mines cuts the revs out at like maybe 6500 somewhere around there. Might wanna put a oil cooler on if your gonna run that high of RPMS 8500- 9000 thats crazy. I wonder if a guy could chrome the internals for better performance?
Friday, July 27, 2007 10:22 PM
Thanks thats good advice, I'd probably get valve float otherwise.
When I add everything up it looks like around 1100 for this valve train right? Is there any discount code for that?
We're talking about an ecotec here, Im using a stand alone Tec3r so I can choose my rev limit.
Saturday, July 28, 2007 9:52 AM
Jacob Smith wrote:I don't see comp cams for the LD9 either
Ferrea ONLY makes parts for the ecotec.
-Aaron
Saturday, July 28, 2007 9:54 AM
I run the Electromotive TEC 3 also with the comp cams stage 3 and ferrea setup, I love it.
We can get you a discount if you get the cams, and valve train (complete) from us. Email me @ Aaron@TurboTechRacing.com for a discount code.
-Aaron
Saturday, July 28, 2007 4:00 PM
Thanks alot man!
Unfortunately (for me) i already bought the cams.............
Ill contact you in the next little while to order regardless.
Sunday, July 29, 2007 4:33 PM
Thanks alot man!
Sounds great, let us know if you have any other questions...
-Aaron
Sunday, July 29, 2007 9:16 PM
BTW, if you already purchased the cams and they were from us, we can still get you a discount just not a discount on the cams as that order is complete (if that makes sense)
-Aaron
