tach driver/adapter - Performance Forum
tach driver/adapter
Tuesday, July 31, 2007 12:37 PM
yea i know you need one for 99 cavaliers and up cuz we dont have a distributer but i was just wondering were i could get one for cheap just need suggestions thanks
Re: tach driver/adapter
Tuesday, July 31, 2007 2:35 PM
No cavalier has a distributor... at least not from the 87 through 05's I have experience with...
You can pick up a signal off of the coil trigger and set the tach for 2 cylinder mode, or you can buy a tach adapter (just search google).
Tuesday, July 31, 2007 2:47 PM
i got my autometer unit on ebay for $60 shipped about a year ago... i really dont think you'll get it much cheaper than that. this is the unit i have, works flawlessly.
Wednesday, August 01, 2007 4:46 AM
what are you guys trying to drive with this?
On a similar note, if using an MSD Dis-2, is a tach adapter required to run your factory tach?
Wednesday, August 01, 2007 9:55 AM
I have the autometer adaptor as well. Piece of cake to install and it runs my pretty little autometer 2 1/16th tach.
Wednesday, August 01, 2007 10:04 AM
but all you guys are doing is running tachs with them? From my remote start install days, to get a tach signal, you should just be able to get it off the fuel injectors, I have no idea about the accuracy of that, since all a remote start needs to see is that the engine is running...
Now what I dont know and would like to find out is the MSD Dis 2 stuff, and using a tach adapter on that....anyone?
Wednesday, August 01, 2007 11:00 AM
CHEVROLET, CAVALIER, Tachometer
purple wire with a white stripe located in the engine harness.
The engine harness is found next to the battery, below the radiator hose, just above the transaxle. This harness has a 2 inch black split loom around it.
01' Z24 5 speed
422whp/400wtq
T4 Turbocharged
Built LD9
HP Tuners
Wednesday, August 01, 2007 11:17 AM
RKSport tach adapter - $32.95
This is the one I have and it works great. Mine provides a rpm signal to my extra injector controller. It's very accurate.
_________________________________________
450WHP Turbo Ecotec swap in the works...
Wednesday, August 01, 2007 12:02 PM
John Benham wrote:From my remote start install days, to get a tach signal, you should just be able to get it off the fuel injectors, I have no idea about the accuracy of that, since all a remote start needs to see is that the engine is running...
the only problem w/ that is that this gives you 1/2 the actual rpm of the engine. if you have a tach thats 2 cyl. capable, this isnt a problem for you.
Wednesday, August 01, 2007 3:03 PM
On a 99 cavalier the white wire going into the ignition control module will give you the tach signal. ^^^^^You're right about the 1/2 rpm issue. I have an Autometer DPSS and it allows you to set the signal interval to allow for scaling the actual rpm correctly, mine is set to 1 to display the rpm correctly. You will need a tach adapter if you don't have an MSD unit or a tach that allows you to select the interval to determine the right display rpm.
Wednesday, August 01, 2007 8:40 PM
Spilner521 wrote:RKSport tach adapter - $32.95
You would happen to have some pics of the install by chance? I have the RKSport tach adapter and a GlowShift tinted tachometer but I am getting no readings out of the tach. When I start my car, the needle jumps all the way-up then falls back down to 0 and just sits there. I'm unsure as to what maybe hooked up wrong.
______
Inochi
Wednesday, August 01, 2007 8:45 PM
I don't have any pics of that actually. I installed it exactly as it was shown in the directions and it works perfect...if that helps you any...
Wednesday, August 01, 2007 9:25 PM
John is right you can get tach signal from the uncommon side of the injector....if Rich is right (which im sure he is cuz i dont know) then just get a tach with 2 cycles....problem solved and easy install....plus you should save money....GL
Thursday, August 02, 2007 6:34 AM
Spilner521 - did you wire the tach adapter into the 2-wire plug or the 6-wire plug?
______
Inochi
Thursday, August 02, 2007 11:20 PM
I don't remember off hand how many wires were in the plug, but I spliced into the wires that plug into the ignition control module under the IDI cover. I'm pretty sure that's where the directions showed to splice in.
