i see that venom makes a performance fuel rail for the 2.4's but i dont see any for my 2200... i have the injectors, but the rail i have is stock... will i be ok? and where could i possibly find a rail if i need one.... thank's
where can you get performance parts for a 2.2 ohv like injectors and that stuff...can you put injector whitout modding anything else???
cant find one... its stamped tin/alloy.
you can find a piece of extruded fuel rail and make a custom one. outside of looks the stock rail can handle most anything you throw at it....
for injectors, check the boost forum, you will prob end up using ones from a different car, or from rceng.com that is, if you are actually doing something that requires extra fuel....boltons really dont. fuel pressure can be adjusted to take care of anything non boost, and non nitrous.
Andre Allard wrote:where can you get performance parts for a 2.2 ohv like injectors and that stuff...
Read the OHV threads in here, Madjack has posted plenty of links.
Andre Allard wrote:can you put injector whitout modding anything else???
No, you'll flood your engine, you need to be able to tune the pulsewidth down.
It's hard to make a one-off based on the extruded Al due to the angle of the injectors, and like Event said, the stock rail will flow much more than you'll ever need.
true.. most shops state you will need injector bungs. i think the angle is like 60 or 70 degrees... its an awkward angle, but it can be done. but the bungs would have to be welded in, or if you machine it, to screw in.... you may be able to tap the rail as in, but the material at the angle makes it harder without the bungs...
