I don't know if this has been posted before or what, but I was browsing around the interweb, and found this...
click. They are new castings (NON-remanufactured)
...and for those to lazy to click...
GENERAL MOTORS 2.3L/138 L4 (Oldsmobile eng.)
1995-94; Vin A, D; DOHC; Quad 4; 16 Valve; w/o Notch at Thermostat Opening;
Head Casting: 456
NH9006
1993; Vin A, D; DOHC; Quad 4; 16 Valve; w/Notch at Thermostat Opening; Head
Casting: 086; 2 Center Bolt Holes on Intake Side Are 10mm
NH9037
Casting: 955; 2 Center Bolt Holes on Intake Side Are 8mm
NH9034
1992-89; Vin D; DOHC; Quad 4; 16 Valve; w/Notch at Thermostat Opening;
Head Casting: 086; 2 Center Bolt Holes on Intake Side Are 10mm
NH9038
Head Casting: 955; 2 Center Bolt Holes on Intake Side Are 8mm
NH9035
1989-87; Vin D; DOHC; Quad 4; 16 Valve; w/Notch at Thermostat Opening;
NH9039
NH9036
The catalog is almost a year old, so I would assume that some have already seen it. I called Hi-Tech personally, and they said they don't deal with the public. The guy told me to go to NAPA and give them the part number for a price.
"Youth in Asia"...I don't see anything wrong with that.
STICKY!
-Trailblazer SS - not so custom 6.0L - custom intake - custom tune
- (1) 2.4L on an engine stand (1) blown trans (2) good quad trans (1) eco trans = party
NH9038
$560 for a brand new assembled head is one hell of a deal. I may have to get one next summer and install some SS valves.
Great find!
too bad there's no ld9 heads
sleepy sunfire wrote:too bad there's no ld9 heads
with a decent hot tank from a machine shop, a very light head surface decking, new valve springs, new valves, new valve seals, new valve guides you could end up with basically a brand new ld9 head, and for about the same price, pry acctually less.
you can either go to advance or auto zone with that part number and also get it.
<a href = 'http://ivpnewmedia.com/10thst/tifts/'>
<img src = 'http://ivpnewmedia.com/10thst/tifts/dpBanner.gif'></a>
does all the 2.3 head has the same valves?
the 955 and 086 might be the same size (I'm thinking the 086 are larger). I'm almost positive the 456 have smaller valves, though. Contact Karo, I'm sure he could tell you for sure.
