hey guys, i was just woundering if anyone had any tips on how to gain small amounts of power fer relatively low prices. i was also woundering, if you upgrade say spark plugs and the wires, does it give much hp? if so wat would be a good brand/model of each?
Youre not going to get much power out of an ignition setup, nothing noticible anyways. Stock AC delco plugs are the best bet for an n/a setup. The MSD CoilPacks are an upgrade, but dont ofer much in the way of HP gain, my setup just has a cleaner idle and a tid more throttle response from the MSD's.
Easy power? Something like an intake, or exhaust. -- its not inexpensive in all cases depending on what you buy, but its easy to install.
Theres other mods that arent so much money, but it depends on what motor/car you have.
fill out your profile. you know where you put in your car info. cheap power and routene maitance are 2 diffrent things also. if you have a 2.2 ohv or 2200 ohv motor swap is the cheapest power gain plain and simple. everything else read the facts all of time and information was put into those for a reason to help newbs.
easy power isnt always adding think the other way. if you remove ac and some are against this power steering that relieves parastitic drag on the crank and thats $10 price of a new belt. also an intake is cheap but if you want it cheaper but som 3 or 4 inch aluminum tube stock from a metal shop have an exhaust shop mandrel bend it for you or you can go real cheap and heat an bend yourself. then purchase a filter. also any weight redux will help you move faster, hp dont go up but theres less drag.
50 shot of nitrous
that'll give you........ maybe 50 HP??? for about $10 a HP thats a bargain
Listen F***ers. FASTERTHANAHONDA is a joke because I WORK FOR HONDA. I'll talk @!#$ about Fords to, that doesn't mean I can beat a 12 second mustang.
blake shuya wrote:how to gain small amounts of power fer relatively low prices.
There is no such thing in a 4 cylinder J-car world. You could sell your car and buy an older V8 Mustang or Camaro if you want cheap power.
kw_z24 wrote:power isnt cheap
Applies to politics as well
pick up a dremel tool, drill, porting kit, a book, and a bunch of heads and intakes from the junk yard to pracktice porting on.
it might take you a while but once you get good at that you can get cheap power out of anything
Those so naive, so hard headed, so narcissistic, that think that buy their own efforts can single handedly change the world, are always the ones that do.
cars are not cheap, you want some go, be prepared to fork out the dough
12.33 @ 111.67 mph [Oct 2009]
327.6 WHP 333.6 WTQ [10.1 AFR]
