well in the process of figuring out what is going on with my car after the swap....
i found a plug that i dont know what it is or where it goes. heres a few pic.
<object classid="clsid:d27cdb6e-ae6d-11cf-96b8-444553540000" codebase="http://download.macromedia.com/pub/shockwave/cabs/flash/swflash.cab#version=6,0,0,0" width="300" height="40"><param name="movie" value="http://www.battlerecord.com/swfs/halo3sm.swf?g=Shaune+Drake&b=halo3sm2"/><param name="quality" value="high"/><embed src="http://www.battlerecord.com/swfs/halo3sm.swf?g=Shaune+Drake&b=halo3sm2" quality="high" width="300" height="40" align="middle" type="application/x-shockwave-flash" pluginspage="http://www.macromedia.com/go/getflashplayer"/></object>
It looks like an o2 sensor connector to me.
^^ for sureeee
[IMG]http://i13.photobucket.com/albums/a251/viper15230/100_1374.jpg?t=1193109920[IMG]
where does it plug in to??? like area im looking for?
The end you have will be in about the area your in in the pics.  The wire form the sensor (if you have one) will have to be routed up to that connector.  The wire form the sensor to the connector is about 3 feet long (rough estimate form memory).
the other end may have fell down. you may have to crawl under your car and look after the cat and follow that o2 sensor till you find the other end. i just put my motor back in this past weekend and i ran into the same problem
ok thanks guy ill let you know what i find out.
