can i just use the regular stock bolts? or do i need to get new ones? i looked at the stock bolts and they dont look damaged in any way at all. if i do need to get new bolts how much are they?
i re used stock. worked fine for me.
okay cool looks like ill install it right now lol i got it in all red to match my valve cover and intake
I also used the stock bolts
Make sure everything is lined up before re installing the bolts. Don't wanna strip them
i jsut got it installed but i can install the bolt on the top front part of the mount all the way to torque specs or else it rubs the belt pretty hard. anyone else run into this problem?
bump i really want this fixed i dont want to drive around with a loose bolt! can i just cut off a bit of the bolt? or use some more washers to rais it up a bit? or can i just tighten it down all the way and have the round end of the bolt rub the belt
Rub the belt?
You may be able to use washers.
But how far does the bolt go down with the factory mount?
Also, your registry says your running the OVH?
-M
Photos would help a lot
-Aaron
www.TurboTechRacing.com
ill try and take some phots but only camera i have is a phone cam. it rubs the belt as in it hits the belt and the belt bends under neath it. and by belt i mean serpantine belt.
i dont know how far the bolt went down on stock mount as i ddint look at it before i took it off
^^^All of the above is very strange, I cant picture what is happening, from what you are saying, pics please
-Aaron
