ok so i was searching around mantapart.com and was wondering which would gain me more power i know biggers not always better thats why im asking. which would be best to go with the sports big bore TB (56mm) or there 60mm throttle body, and if i did get either would i have to get anything else to coinside with the new tb. also i would gain more power with this as opposed to a 4-1 header?
You should probably avoid mantapart.com because they have been known to take the money and not ship the item out untill a year or two after, if at all. They are haveing some legal problems at the minute as well. As far as a tb or header, I would go with the header first. If you want to get the throttle body, switch for the 2.3 ho tb, its 56mm and is probably a lot cheaper.
Look up SMG they will bore your stock 2.4tb to 56mm for you.
mantaparts phone doesnt even work now....so looking on their site was probably your first mistake
ok so as far as the header bein a better idea, everyone here has pacesetter or something else..every tech that i work with has told me that getting pacesetters are cheap and wont do me any good. are these worth getting or would something like the weapon r;s be better.
ive had my pacesetter for almost 4 years now.  no problems on my end.
you might want to get the ceramic coated pacesetter header
yeah that would be my only option ..the ceramic coated, so with a nice set up for exhaust its possible you will feel a difference.
more than likely you would
