Does anyone have a issue with the vibrant exhaust hanging low under the car? right around the gas tank area? Mine hangs low there and also hits on the rear axle beam as well. It's driving me freakin insane and it needs to be fixed. anyone had any suggestions for me?
Guess not. Must be an installation problem. Is there anyway to tuck it up more? Maybe you could modify the brackets to get it higher up? How was it installed? By yourself, or at a shop?
The01Cav wrote:Does anyone have a issue with the vibrant exhaust hanging low under the car? right around the gas tank area? Mine hangs low there and also hits on the rear axle beam as well. It's driving me freakin insane and it needs to be fixed. anyone had any suggestions for me?
check the condition of your hanger and rubber part of the hanger.
if you look at older cavaliers the problem is the same on the stock exhaust.
many times its the metal part has been bent or the rubber is stretched. easily replaceable.
