ok it's the 3rd day i am trying to hook up this piece of sh*t, with no luck.
did anybody here get it to work or is it just me??
i've hooked up to pink wire at first... didn't work then i went according to their manual and hooked it up to a white and orange, no response whatsoever
anybody that got it to work please tell me what to do!!!
the pink wire is not were u hook up to u found that out i assume, the small red goes to the white it might be faded yellow a little bit i know mine was and the small black to orange, i spliced them in make sure its spliced correctly, then run the bigger red wire off the tach ad to the green wire from the tach
Mark Raimo wrote:the pink wire is not were u hook up to u found that out i assume, the small red goes to the white it might be faded yellow a little bit i know mine was and the small black to orange, i spliced them in make sure its spliced correctly, then run the bigger red wire off the tach ad to the green wire from the tach
Wow you got your to work. I'm on my second adapter from RK and I still don't have mine working for about 8 months. Also doesn't help that I haven't tried to get it work in about 6 months. Haven' t had much wrench time since I'm moved. Might have to try to make it work again today.
______
Inochi
lol i wired this when i had no experience at all its very simple. right were the spark plug cover that says eco tec if its eco like mine theres the icm, off the icm, visible is the white and orange wires there very very easy to fine.. although mine is wired correctly i have had problems with the rk sport and every once and a while it gives me half reading, and ive heard there known to break
