I was looking at getting some RK Sport motor mounts and was wondering if the upper mount insert is needed or if the lower mount will be just fine alone
i drove my car with just the lower for a bit, loved it, then added the upper. (ordered both at the same time just too lazy to put the upper in) and loved it even more, made the engine much less sloppy.
Veritas Aequitas
yeah, your going to get increase vibration no matter what, so you might as well secure the engine as good as possible and put both in at the same time. Definatly a noticable difference when your driving it. It seems more "responsive"
the upper insert is only $17....why wouldnt you get it?
I am gonna go with both, was just curious if its really important cause i know it can be pain.
wondering if anyone knows how hard it is to install the rk sport lower mount...I know the upper mount insert isn't too bad to get at..
lower mount is easier than the upper
yea the Lower mount isn't hard at all but i've heard that the upper insert can be a pain but overall not to bad
Get the TTR mount
Much better than the RK Sport inserts hands down
on the upper insert you are just basically taking out the stock insert and replacing it.
and just to clarify i have the RK Sport mounts... well lower and upper insert..
the TTR mount is easier to put in simply because you are just swapping the entire mount.
Veritas Aequitas
