Trans mount installs - Performance Forum
Monday, May 12, 2008 2:06 AM
Hey people,
Any tips or tricks on installing the poly trans mounts??? I searched and couldn't find any instructions on it. Any help would be appreciated. Thanks
Re: Trans mount installs
Monday, May 12, 2008 4:00 AM
what part are you having a hard time with?
the rear one can be tricky, but you can get it in and out through the top with the right socket extensions. just once its loose you are gong to have to do some jiggling to get it out and some jiggling to get it back in. pull it up through the back of the motor and don't even think about going up between the brake master cylander and the shock tower. it looks like it will go but trust me, it won't
the front one to get the bolt out I had to pull down the inner fenderwell and thake the washer tank down but it wasant by any means hard to do
as fat as the bushing in the mount, just pull back the tabs with pliers and knock them out with a hammer.
I forced my poly mounts in by hand (literally) I was able to get them half way down then I tapped it the rest of the way in with a hammer. this caused no damage to the bushing and I have been running on these mounts for over 8k miles
Those so naive, so hard headed, so narcissistic, that think that buy their own efforts can single handedly change the world, are always the ones that do.
