Well i know everyone hates header threads heh but i just wanna know if anyone has ever used this stainless header i keep seeing on ebay. it looks really good but does it fit without mods??
Clicky to see header
Looks identical to the pacesetter one. So it should fit just fine...
Cody@RDFabs.com wrote:Looks identical to the pacesetter one. So it should fit just fine...
thats what they said about the OBX stuff.....which LOOKS identical but doesnt line up right.
You take a chance with that stuff. Just prepare yourself to eat the cost if it doesnt work right.
Hi I got this header on my sunfire 2.4 and all you need to do to fit it perfectly is to grind a little bit the 4 holes that connects to the engine, the rest is bolt-on! Also, I didn't plug the sensor in it so I've closed the hole.
so you have a 2200 ohv header on your 2.4?? how does that work out?? does anyone else know if this is garbage or not?? if it is whats the best cheap header you can buy?? obx pacesetter this stainless ones ???????? what does eveyone else use
Stay away from obx. Alot of people here use the pacesetter
guy on Aleromod is using the OBX on the LD9 without issue
but they're a knockoff eBay brand, they stole Tenzo Racing Sport's logo style
2001 Olds Alero (LD9)
650 whp / 543 ft-lb
@turboalero
I had an OBX and had no issues with it after I beveled one of the runner ports. Prefered it over the Stans header I had on before that. SOld the OBX so now im stuck wit teh Stans until I go turbo again.
Stephane Demers wrote:Also, I didn't plug the sensor in it so I've closed the hole.
so you are not running a front o2 sensor? you do realize that is a BAD thing, right?
^^^do you think that guy is serious
