check oil - Performance Forum
check oil
Thursday, July 03, 2008 9:14 AM
my check oil light is on ,but i just changed my oil, you think this is a bad sensor, let me know thanks (ld9)
Re: check oil
Thursday, July 03, 2008 9:59 AM
did you check your oil??
perhaps there is a leak due to the oil change...loose plug, double gasket etc....
I would check your oil before thinking it is a faulty sensor.
Re: check oil
Thursday, July 03, 2008 10:27 AM
i just checked it and its not leaking ,but i heard before that the ld9 motors are known to have those bad sensors just thought i would check here to make sure before i start buying sensors
<a href="http://tinypic.com" target="_blank"><img src="http://i31.tinypic.com/ip1g8k.jpg" border="0" alt="Image and video hosting by TinyPic"></a>
Re: check oil
Thursday, July 03, 2008 11:31 AM
before you start buying parts and throwing them at the problem. test the sensor.
Re: check oil
Thursday, July 03, 2008 12:14 PM
Since you checked the oil and it is full, then I would go with the sensor being bad. I would check to make sure it is still plugged in as well. 96 was the only year the LD9 had that sensor. I think there is a reason.
Re: check oil
Thursday, July 03, 2008 7:38 PM
anyone know off hand were that sensor is thanx
http://memimage.cardomain.com/member_images/3/web/3111000-3111999/3111439_1_thumb.jpg?
Re: check oil
Thursday, July 03, 2008 9:17 PM
its in the oil pan.
Re: check oil
Thursday, July 03, 2008 11:10 PM
Im no mod or anything but why is this in performance? unless you used some crazy fast Japaneses race oil and now your EOL is on...
