my 95 2.2 ohv is idling t 3000 rpm i checked the injectors yesterday and cleaned the upper intake and now it revs hi how do i fix this
Look for cracked or broken  vaccumm hoses.
i have they are fine to i just forgot to say that
my uncle said it may be the intake gaskit between the upper and lower manifolds
Could possibly be a leaking gasket or also your IAC could be the problem.
ive always been told its tps if it idles high but i dont know with that high of idle, could have knocked it out of adjustment?
Unless you unbolted it, not really. Did you reuse the factory intake manifold plennum gasket (Just asking)? And did you torque it all according to specs (Again, just asking)?
I seriously doubt it's a TPS fault. Check the throttle-valve. Does it close fully? This seems like an IAC fault to me, as I've seen others have that problem & they all found that to be the cause. It happens. Try a known working IAC & do the reset procedure to see if it is.
Go beyond the "bolt-on".
yes i did all that and new gasket i tried the tps and thats not it is there any other way to test the iac
What I did on my Z when I had this problem was took a can of carb cleaner, spray not foam. and spray it everywhere on the intake and all my vacuum lines until I could hear the idle drop, then you know where your leak is, cause most likely you have a bad vacuum leak somewhere.
"sometimes the respect is more important..."
on my 2000 2.2 OHV cav i messed around with same same problem ( i no its not the EXACT same motor ) i ended up haveing a slight bend in my throttle cable that held it at 2500ish rpm ? hope this might help yah out
schmidty4343 wrote:What I did on my Z when I had this problem was took a can of carb cleaner, spray not foam. and spray it everywhere on the intake and all my vacuum lines until I could hear the idle drop, then you know where your leak is, cause most likely you have a bad vacuum leak somewhere.
the carb cleaner trick raises the idle it doesnt drop it. Carb cleaner is highly flammable so when sucked in it raises the idle.
To op, if you have a friend with a motor similar to yours pop theirs out and put it in yours. If im not mistaken, the IAC has two bolts and a pigtail that you have to remove and it comes out.
its all good now the gasket was kinked its fixed now
