02 sensor - Performance Forum
02 sensor
Wednesday, August 13, 2008 1:52 PM
i didnt know where else to put this but after i put my exhaust in my upstream o2 sensor is further then stock is it ok to cut and splice these wires?
"how do you get in"
Re: 02 sensor
Wednesday, August 13, 2008 2:36 PM
Re: 02 sensor
Wednesday, August 13, 2008 6:21 PM
so the code im getting is p1133 that has nothing to do with the fact i cut and spliced the wire its an o2 sensor code i know that much but dont know exactley what it is
"how do you get in"
Re: 02 sensor
Thursday, August 14, 2008 7:58 PM
P1133 = Heated Oxygen Sensor (HO2S) insufficient switching bank 1 sensor 1 (Rear Bank)
You might want to check your splicing just in case it came apart.
Re: 02 sensor
Friday, August 15, 2008 9:23 AM
Once you splice in youre wiring harness youre gonna want to get some heat shrink covering for thr bare wires cause, water and dirty get into there, Youre gonna have short in youre wiring, All some those butt connectors are no good for that either, Just twist the wires together, heart shrink them youre set.
Good Luck.
Re: 02 sensor
Sunday, August 17, 2008 10:23 AM
well i spliced the up one before the cat that one isnt heated though is it?
"how do you get in"
Re: 02 sensor
Sunday, August 17, 2008 7:08 PM
well, I am not sure about a 2.2 on a 98, but I have a 2.4 twin cam 98 and the upstream (one on the manifold) is not a heated o2. I am almost 100% for sure yours is not either. If it has 1 wire, then no, it is not a heated o2...
98z24, lowered 2", aem intake, cat-back striaght pipes!, cop ligths in the front and rear, 18" liquid metal's, primer black, tint, full audio and video.
Re: 02 sensor
Monday, August 18, 2008 1:41 PM
its not its a 1 wire o2 sensor
"how do you get in"
Re: 02 sensor
Monday, August 18, 2008 1:43 PM
How did you splice it? Solder the wires or twisted them together?
Re: 02 sensor
Friday, August 22, 2008 10:21 PM
butt splices
"how do you get in"
Re: 02 sensor
Saturday, August 23, 2008 2:32 PM
jere k wrote:butt splices
those are no good. they've corroded, you need to cut, solder , and heat shrink it.
Re: 02 sensor
Sunday, August 24, 2008 9:11 AM
ok ill try that and see if that works with my pre cat o2 sensor not working rite will that mess with how my car runs?
"how do you get in"
